Verifying Inner Product Properties on a Circle Function
quasar987
Hi guys, there's a problem to which me and my pals just can't seem to get an answer that is congruent the answer on the back of the book. The homwork is due in two days and I just want to make sure the book is truly wrong. The question's simple enough: given f,g continuous on the circle ([-pi,pi)), is
(f,g)=\int_0^{\pi} fg^*dt
an inner product on the space of continuous functions defined on the circle?
We're saying yes because the 3 properties are verified:
i) (af+bg,h) = a(f,h)+b(g,h), as if evident by the properties of the integral.
ii) (f,g)^* = \left( \int_0^{\pi} gf^*dt \right)^* = \int_0^{\pi} (gf^*)^*dt = \int_0^{\pi} fg^*dt = (g,f)
iii) (f,f) = \int_0^{\pi} ff^*dt = \int_0^{\pi} |f|^2 dt \geq 0
(since |f| >= 0 and = 0 <==> f=0)
Hence all 3 properties are verified. Any objection?
Are these complex functions of a real variable? Is * complex conjugation or convolution?
It seems clear by iii that * is complex conjugation.
yeah.
Is there a reason why the integral is only from 0 to \pi when the functions are defined on the entire unit circle (in the complex plane)?
Suppose f(x) were define to be 0 for t between 0 and \pi and sin(t) when t is between \pi and 2\pi.
What is \int ff*dt then?
Ok, I see. I just received a call from aforementioned pals who just found the 'ick'.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
