Instant Heat Packs: How Reusable Packs Work
  • Thread starter Thread starter SkepticJ
    Heat
Instant, reusable heat packs operate using a supersaturated solution of Sodium Acetate, which is metastable and can release heat when crystallization occurs. The process is initiated by clicking a metallic button inside the pack, creating a nucleation site that triggers the formation of Sodium Acetate Trihydrate crystals, releasing heat in an exothermic reaction. These heat packs can be reused by dissolving the crystals back into the solution through heating in boiling or warm water, allowing the solution to cool and become supersaturated again for future use. This phenomenon is often demonstrated in chemistry as "Hot Ice," where the solution appears like water but feels warm when crystallization is triggered.
Chemistry news on Phys.org
Inside the heat packs there is a supersaturated solution of Sodium Acetate. The supersaturated solution is metastable / unstable since too much Sodium Acetate is dissolve in solution for its temperature. Upon being triggered (by clicking the metallic button inside the pack), a nucleation site is provided for Sodium Acetate crystals to begin to form. As the crystallization process proceeds, Sodium Acetate Trihydrate is formed and the whole process is exothermic (will give off heat).
The heat packs are reusable since you can easily re-dissolve the Sodium Acetate crystals again by heating the contents in boiling (or even just warm) water. The Sodium Acetate Trihydrate will “melt” / dissolve, then you allow the pack to cool back down to room temperature and the solution becomes supersaturated again. Then you can just repeat the process.
A common chemistry demo preformed to demonstrate supersaturated solutions is sometimes called “Hot Ice”, in which a supersaturated solution of Sodium Acetate is triggered by touching it or dropping in a seed crystal. The solution, which initially appears to be water, seems to freeze…only the “ice” is warm to the touch.
See this web page for additional details,
http://www.amazingrust.com/Experiments/how_to/Hot-Ice.html
Thank you.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
