What Formula Do I Use to Find Instantaneous Velocity?
To find instantaneous velocity, it's essential to understand that it represents the speed and direction of an object at a specific moment, similar to a car's speedometer reading. In calculus, instantaneous velocity is determined by the first derivative of the position function with respect to time, which reflects the slope of the tangent line on a displacement vs. time graph. For non-calculus scenarios, you can calculate it using kinematic equations, such as adding initial velocity to the product of acceleration and time. For example, if an object accelerates from 3 m/s at 5 m/s² for 7 seconds, its instantaneous velocity would be 38 m/s. Providing context for your question can lead to more tailored assistance.
Iceclover
I was just confused on what formula i use to find instantaneous velocity if anyone can give me an example or explain how i figure it out that would be great. thanks!
Formula? Well, not specifically a formula. However, you understand what instantaneous velocity is, right? It's what the speedometer of the car says (plus the direction the car is traveling.) If the car is traveling at a constant speed, then the instantaneous speed is the same speed throughout the time it's traveling.
If you look at it in a graphical sense; specifically a graph of displacement vs. time, the instantaneous velocity is the rate of change of the curve at any particular point. (Also stated as the slope of the curve, or more correctly, the slope of the tangent line to the curve at a point.) If you're in a calculus based physics course, the instantaneous velocity would be the first derivative of the position function, with respect to time.
i still don't really get it?
If you are using calculus in your physics class, then the instantaneous velocity is the derivative of the displacement function.
If you're not using calculus, then, I suppose, the answer is "it all depends."
For example, if an object starts at 3 m/s, and accelerates at 5 m/s^2 for 8 seconds, and you're wondering what the instantaneous velocity is after 7 seconds, then just treat the 7 second time as when a final velocity occurs. i.e. 3m/s + 5 m/s^2 * 7s = 38m/s
If you throw a ball horizontally at 10 m/s off a cliff, then the horizontal component of velocity will always be 10m/s (til it hits the ground, and as usual, ignoring air resistance.) The vertical component of velocity will be increasing at 9.81 m/s^2. So, after 3 seconds, it's vertical component of velocity will be 3 * 9.81 m/s = 29.43 m/s. You can find the instantaneous velocity at the 3 second point by applying the pythagorean theorem.
If you have a car traveling at a constant velocity of 4 m/s East, then at the 1 second point, 2 second point, and any other point in time while it's moving, the instantaneous velocity is 4m/s East.
Perhaps if you put your question into context, I could help you better.
