Integral against E is 0, show m(E)=0
  • Thread starter Thread starter Newtime
    Integral
Newtime
Let f >0 a.e. be measurable. If \int_E f = 0 for some measurable set E then show m(E)=0.
This is about 10 pages into the chapter on Lebesgue integration, so I'm using the definition, a few immediate corollaries and the lemma that if f is nonnegative and measurable and its integral is 0 then f is 0 a.e.
While working on this problem I completed several proofs, all of which had fault assumptions. For example, if I can assume f is integrable, then I can use a separate lemma and complete the proof. But of courses, I cannot make this assumption.
If we define a function g to be f restricted to the set on which it is nonnegative, and replace g in the problem statement with g then I can prove the result as well. So I was trying to get to the implication that if the integral of f against E is zero than the integral of g against E is zero as well. But this doesn't seem lie it needs to be true either.
I think this is a simple problem that I'm over thinking (I hope). In any case, I think a small nudge in the right direction will clear things up. Thanks.
Newtime said:
[...]the lemma that if f is nonnegative and measurable and its integral is 0 then f is 0 a.e.
That sounds relevant indeed... if I read it correctly then you want to prove exactly this if f is not measurable everywhere, but almost everywhere.
So then, maybe you can approximate f by a series of everywhere non-negative measurable functions?
Thanks for the reply, CompuChip. You are correct that I basically am looking to generalize that lemma. Regarding approximating f: this can be done as well. There is a lemma which says that f is measurable if and only if it's the pointwise limit of a sequence of measurable simple functions. However, these functions may still be (and would be) not (necessarily) non-negative. There is an analogous result that guarantees each of the simple functions are nonnegative but of course the additional assumption is that f is nonnegative to begin with. This is what led me to consider the set D of all elements of the domain on which f is less than or equal to zero and then the function g which is 0 on this set and f everywhere else. Do you see a way around this? Or is there no problem to begin with and perhaps I'm overlooking something?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
