Integral containing something over the root of x²-a²
  • Thread starter Thread starter Telemachus
    Integral Root
Telemachus
Evaluate the next integrals, expressing it previously in the forms that contains \sqrt[ ]{a^2+u^2}, \sqrt[ ]{a^2-u^2} and \sqrt[ ]{u^2-a^2}, and then solve it using the integral table;
The exercise which I couldn't solve:
\displaystyle\int_{}^{}\displaystyle\frac{x+3}{\sqrt[ ]{x^2+2x}}dx
I started by completing the square:
x^2+2x=(x+1)^2-1
Then
u^2=(x+1)^2
u=(x+1)\Rightarrow{x+3=u+2}
du=dx
\displaystyle\int_{}^{}\displaystyle\frac{x+3}{\sqrt[ ]{x^2+2x}}dx=\displaystyle\int_{}^{}\displaystyle\frac{u+2}{\sqrt[ ]{u^2-1}}du
From here I've tried to solve it by parts
t=u+2
dt=du
dv=\displaystyle\frac{1}{\sqrt[ ]{u^2-1}}du
v=\ln|u+\sqrt[ ]{u^2-1}|
\displaystyle\int_{}^{}\displaystyle\frac{u+2}{\sqrt[ ]{u^2-1}}du=(u+2)\ln|u+\sqrt[ ]{u^2-1}|-\displaystyle\int_{}^{}\ln|u+\sqrt[ ]{u^2-1}|du
If I try again by parts with -\displaystyle\int_{}^{}\ln|u+\sqrt[ ]{u^2-1}|du it gets more complicated.
So, what do you say?
Bye there.
You can do integral u/sqrt(u^2-1) with a simple substitution. So split (u+2)/sqrt(u^2-1) up into two integrals.
The integral
<br /> \int\frac{u+2}{\sqrt{u^{2}-1}}du<br />
Can be computed by the substitution
<br /> u=\cosh v<br />
Everything should come out in the wash then
Thank you both.
This is what I wasn't seeing:
Bye there!
I've arrived to this solution:
\displaystyle\int_{}^{}\displaystyle\frac{x+3}{\sqrt[ ]{x^2+2x}}dx=\sqrt[ ]{(x+1)^2-1}+2\ln|x+1+\sqrt[ ]{(x+1)^2-1}|+C
Seems ok to me. I would write x^2+2*x instead of (x+1)^2-1. But that's up to you.
Thanks Dick. BTW nice nickname :D
yup, got the same answer !
P.S: anyone knows a program that writes LaTeX and has an intuitive interface? :)
