Integral Domain, r^2 = r proof that r = 0 or 1
RJLiberator
Let r be an element of an integral domain R such that r^2 = r. Show that either r = 0_R or 1_R
integral domain means no zero divisors.
This is fundamental as 0 and 1 solve r^2 = r and are the only solutions.
However, I'm not really sure what I can play with to show this fact.
We have r*r = r
There are no zero divisors so no such thing as r*s = 0.
If we start this proof off by assuming r is not 1_R or 0_R then maybe we could get somewhere, but It doesn't feel promising.
There has to be a way to use the fact that r^2 = r.
(r^2)*r = r^2 ?
Then we are left with r*r = r, that's no good.
Is there any trick that I am neglecting? I feel this is just a simple multiplication of two things and boom we have r(r^2) = 0 or 1 or something.
How about r^2 - r = r-r
then we have
r(r-1)=0
r is either 0 or 1.
BOOM?
When the problem talks about such things as 0_R and 1_R is it safe to assume that they just mean 0_R = 0 and 1_R =1 ?
For instance, my proof has the following:
r^2 = r
r^2 - r = r - r
r(1-r) = 0
Therefore r = 0 or r = 1
But is that a complete proof in consideration of 0_R and 1_R ?
We have r*r = r
(r^2)*r = r^2 ?
then we have
r(r-1)=0
r is either 0 or 1.
BOOM?
The last one is correct. BOOM! :oldsmile:
Likes RJLiberator
Samy_A do you have a moment to check out my reply? I am wondering on the terminology of this problem. :)
r^2 = r
r^2 - r = r - r
r(1-r) = 0
Yes. 0_R is the identity element for addition, 1_R is the identity element for multiplication. It is common to simply write them as 0 and 1, as long as it is clear what ring we are talking about.
Likes RJLiberator
"0_R" and "1_R" specifically mean "the additive identity" and the "multiplicative identity" of the ring, R, respectively. I believe SamyA is saying that it is alright to drop the "R" if it is clear what ring you mean. You cannot assume that they are the numbers 0 and 1 if that was what you meant.
Likes RJLiberator
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
