Integral of x^x Series Representation
Cistra
This has been driving me insane, and I'm sure it's something mind-boggling obvious but I can't seem to find it. I'll go through the work through here, I'm trying to prove that
\int_0^1{x^xdx}=\sum_{n=1}^{\infty}\frac{(-1)^{n+1}}{n^n}.
2. The attempt at a solution
Basically I'm having a negative somewhere that I'm not accounting for in my derivation of this. I'll just go through what I do step by step here until where I'm positive my error occurs...
\int_0^1{x^xdx}=\int_0^1{e^{xln(x)}dx}
e^{xln(x)}dx=\sum_{n=0}^{\infty}\frac{1}{n!}x^nln^n(x)
\sum_{n=0}^{\infty}\frac{1}{n!}\int_0^1x^nln^n(x)dx and then I made the substitution u=-ln(x) or e^{-u}=x,dx=-e^{-u}du and I get after changing the bounds of integration
(-1)^{n+1}{\int_0^{\infty}e^{-u(n+1)}u^ndu
Here's the problem, I'm supposed to get (-1)^n as the constant in the integrand at this point but I can't get that extra -1 to go away. Ignoring that constant the rest of the proof goes out without a hitch, just using the Gamma function etc. but I can't make this silly negative go away! Can anyone see my mistake? =(
Thank you!
*Edit: The rest of the derivation from the last step. I made another substitution v=u(n+1),du=dv/(n+1) and then I get
\frac{(-1)^{n+1}}{n+1}\int_0^{\infty}e^{-v}\left(\frac{v}{n+1}\right)^ndv=\frac{(-1)^{n+1}}{(n+1)^{n+1}}\int_0^{\infty}e^{-v}v^{n}dv.
That last formula is the one for \Gamma(n+1)=n! so then I get after substituting back into the sum,
\sum_{n=0}^{\infty}\frac{n!}{n!}\frac{(-1)^{n+1}}{(n+1)^{n+1}}=\sum_{n=0}^{\infty}\frac{(-1)^{n+1}}{(n+1)^{n+1}}.
Now I do make that substitution into the sum, setting n+1=k I get
\int_0^1x^xdx=\sum_{k=1}^{\infty}\frac{(-1)^k}{k^k}. The problem is that I'm supposed to get (-1)^{k+1} in that final sum rather than (-1)^k.
You'll kick yourself, Cistra: your sum is from n=0, the required sum is from k=1 (replacing their n with k), so at the end just put k=n+1.
Hrm, that's what I did (edited with full derivation above) and I'm off by one power of -1 at my conclusion.
Actually, with your substitution we have
\int_0^1x^nln^n(x)dx = \int_{\infty}^{0}e^{-nu}(-u)^n(-e^{-u}\, du) \,\, = \, \, -(-1)^n\int_{\infty}^{0}e^{-u(n+1)}u^n\, du \, \, = \, \, (-1)^n\int_{0}^{\infty}e^{-u(n+1)}u^n\, du
Argh! I didn't look closely at my bounds...thank you for your assistance Unco.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
