Integral Problem Homework: Attempting Difficult Term
  • Thread starter rjs123
  • Tags
    Integral
In summary, the person is trying to solve an area problem. They forget to integrate the last part and end up with the wrong answer. However, it is correct up to a constant.
rjs123
90
trying to integrate this...the second term is the difficult one here.
[tex] \theta^2 + 2\theta\sin2\theta + sin^2(2\theta)[/tex]
I attempted the problem and ended up with this but it doesn't seem right
[tex]\frac{1}{3}\theta^3-\theta\cos2\theta+ 1/2sin2\theta + \frac{1 - cos4\theta}{2}[/tex]
Not quite. Although the two first integrals are correct. Hint: Write u=2theta and use what you know about trigonometric identities.
i know [tex]sin2\theta[/tex] trig identity is [tex]2sin\theta\cos\theta[/tex]
[tex] u = 2\theta[/tex]
[tex] du = 2d\theta[/tex]
[tex] dv = sin2\theta[/tex] [tex] dv = 2sin\theta\cos\theta[/tex]
this is where i get stuck
Know that:
[tex]\sin^2(x) = \frac{1-\cos(2x)}{2}[/tex].
Well, what's the derivative of [itex]\cos 2\theta [/itex] equal to ? Then use part integration.
Wingeer said:
Know that:
after integrating...
[tex]\frac{1}{3}\theta^3-\theta\cos2\theta+ 1/2sin2\theta + \frac{1}{2}\theta - \frac{1}{8}sin4\theta[/tex]
i forgot to integrate the last part...but this still doesn't seem correct
But it is correct. Up to a constant, of course.
I'm attempting to solve this area problem
[tex]1/2\int_{0}^{\pi }(\theta + sin2\theta)^2 d\theta}[/tex]
The area found by my calculator comes out to be 4.93...but by hand I get 4.38
The original polar equation: [tex] r = \theta + sin(2\theta)[/tex] from 0 to pi.
I think it may by the use of my input into the calculator and not the work done by hand...i'll doublecheck.
[tex]
\frac{1}{3}\theta^3-\theta\cos2\theta+ 1/2\sin2\theta + \frac{1}{2}\theta - \frac{1}{8}\sin4\theta
[/tex]
Add a constant & it looks good to me. Check it by taking the derivative.
SammyS said:
[tex]
[/tex]
yep...i just concluded guys that I was inputting the equation wrong into my calculator...4.38 is the right answer and i was doing it right by hand all along...what a relief.
I have one more question though...
how do I find the angle at which the graph is at x = -2 ?
1. What is an integral problem?
An integral problem is a type of mathematical problem that involves finding the area under a curve or the accumulation of a quantity over an interval. It is solved using a mathematical technique called integration.
2. How do I approach a difficult integral problem?
The key to solving difficult integral problems is to break them down into smaller, more manageable parts. This can be done by using integration rules and techniques, such as substitution, integration by parts, and trigonometric identities. It is also important to practice and develop a strong understanding of the fundamental concepts of integration.
3. What are some tips for attempting difficult integral problems?
Here are some helpful tips for tackling difficult integral problems:
  • Make sure you understand the problem and what is being asked.
  • Break the problem down into smaller parts and use integration rules and techniques.
  • Check your work and make sure your answer makes sense.
  • Practice regularly to improve your skills and speed.
  • Don't be afraid to ask for help when needed.
4. How can I improve my skills in solving integral problems?
One of the best ways to improve your skills in solving integral problems is to practice regularly. You can also seek out additional resources, such as textbooks, online tutorials, or working with a tutor. It is also important to constantly review and reinforce your understanding of the fundamental concepts and techniques of integration.
5. What are some real-life applications of integral problems?
Integral problems have many real-life applications, including:
  • Calculating areas and volumes in engineering and construction projects.
  • Predicting population growth and modeling the spread of diseases in biology and medicine.
  • Calculating work and energy in physics.
  • Modeling the flow of fluids in chemistry and engineering.
  • Analyzing financial data and predicting trends in economics.
