Solving Integral of x|x| from -1 to 1
  • Thread starter Thread starter olds442
    Integral
olds442
integral of x|x|dx.. [-1,1]
when graphing it, it is even (looks like the cubic function) and would be 0... but I am having problems convincing myself of this. i checked it out using my calculator, and it just gives back x|x|.. i know if you do the integral of abs x you would split it up into positive and negative parts and all that.. but this is obviously different since it goes below y=0...
You would still split it up and add the integral for x>0 up with the one for x<0.
I think you mean it's an odd function. And the definite integral from -a to a should give you zero.
If you use the definition for absolute value,
|x| = x for x => 0 , -x for x < 0 ,
then your integrand is
x·|x| = x^2 for x => 0 , -(x^2) for x < 0 .
That will explain the graph and the result for your definite integral.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
