Integrate complex function over unit circle
skrat
Calculate ##\int _Kz^2exp(\frac{2}{z})dz## where ##K## is unit circle.
Hmmm, I am having some troubles here. Here is how I tried:
In general ##\int _\gamma f(z)dz=2\pi i\sum_{k=1}^{n}I(\gamma,a_k)Res(f,a_k)## where in my case ##I(\gamma , a_k)=1##.
Now ##Res(f,a_k)##:
##f(z)=z^2exp(\frac{2}{z})=z^2\sum_{n=0}^{\infty}\frac{1}{n!}(\frac{2}{z})^n=\sum_{n=0}^{\infty}\frac{1}{n!}\frac{2^n}{z^{n-2}}##
To get ##\frac{1}{z}## clearly ##n-2=1## so ##n=3##.
Which gives me ##Res(f , 0)=\frac{4}{3}##.
Therefore ##\int _Kz^2exp(\frac{2}{z})dz=2\pi i \frac{4}{3}##.Or is that completely wrong? Thanks in advance!
This is absolutely correct!
EDIT: Remember you can always verify your Laurent series (the hardest part in my opinion) using WolframAlpha :D
Thank you! =)
You know, I presume that e^x= 1+ x+ x^2/2+ x^3/6+ \cdot\cdot\cdot+ x^n/n!+ \cdot\cdot\cdot.
So e^{2/z}= 1+ 2/z+ 2/z^2+ 4/(3z^3)+ \cdot\cdot\cdot and then
z^2e^{2/z}= z^2+ 2z+ 2+ 4/(3z)+ \cdot\cdot\cdot
The integral around the closed circle of any power of z (positive or negative), except -1, is 0 and the integral of z^{-1} is 2\pi i (which is where the idea of "residue" comes from) so the integral of z^2e^{2/z} around the unit circle is (4/3)(2\pi i)= (8/3)\pi i.
hehe, nicely said Hallsoflvy. Everything is a bit more obvious now. Thank you!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
