Integrating 2-Forms on the Unit Sphere
  • Thread starter Thread starter raw
    Integrate
raw
I want to integrate the 2-form defined on R^3\{0,0,0} over the unit sphere.
(x/r^3)dy wedge dz+(y/r^3)dz wedge dx+(z/r^3)dx wedge dy
r=\sqrt{x^2+y^2+z^2}
I'm thinking this is like a surface integral but I'm not really sure how to go about actually doing the calculation.
First thing to do is convert the 2-form into polar form.
As hunt_mat said, you could just do the direct thing: parametrize the surface and integrate. He suggests polar coordinates; I'm not sure if he really meant cylindrical coordinates or spherical coordinates, though. It might be worth considering plain ordinary rectangular coordinates; the three summands are pretty much already set up as ordinary double integrals.
Normally you'd consider the generalized Stokes' theorem to integrate this. (Green's theorem?) But, alas, the origin is a problem.
So what if you put a tiny sphere around the origin, and used Stokes' theorem on the region between them? Or alternatively a huge sphere. If you can say something useful about the behavior of the integral on very small or very large spheres, this approach could work.
I meant spherical co-ordinates, as Hurkyl said the origin is a problem so, take a small sphere of radius epsilon and exclude that from the domain of integration and then once you have done the integration, take the limit as epsilon tends to zero.
Oh, and by the way, can't you simplify the integrand? :-p
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
