Integrating a Complex Function Over a Contour
Bashyboy
##z(t) = t + it^2## and ##f(z) = z^2 = (x^2 - y^2) + 2iyx##
Because ##f(z)## is analytic everywhere in the plane, the integral of ##f(z)## between the points ##z(1) = (1,1)## and ##z(3) = (3,9)## is independent of the contour (the path taken). So, I can choose a simpler contour which passes through these two points, such as a line.
Using the two points to find the slope, and parameterizing it, we get the straight-line contour
##z_1(\tau) = \tau + i(4 \tau + 3)##.
Here is where I am having difficulty. How exactly do I find the interval between the two points? This is how I did it, but am I unsure if it is correct:
##z(\tau) = (1,1) \implies##
##(\tau, 4 \tau + 3) = (1,1)##
which gives us the two equations
##\tau = 1## and ##4 \tau + 3 = 1##.
However, I get a different ##\tau## value from each equation. What can account for this?
I found the mistake. The straight-line contour should actually be ##z_1(t) = \tau + i(2 \tau \underbrace{-} 3)##
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
