Integrating a complicated polynomial
9 replies · 3K views
Mathpower
Hi
An integration question:
t= 1/(1+r2)
Can you please show me how to integrate with respect to r. Thank you.
∴t = (1+r2)-1
I then tried substituting u = 1+r^2 but that didn't work!
Is there a trick with this?
Well I'll hint and say it has to do with an inverse trig function.
Just so I understand, you're trying to find the integral of this?
[tex]\int \frac{1}{1+r^2}\,dr[/tex]
BTW, what you have after the t is not a polynomial, but a rational expression.
Mathpower said:
∴t = (1+r2)-1
Yes, it's called trigonometric substitution. Try r = tan u.
eumyang...thank you...yes that's what i meant.
NO idea! I tried r= tan u
1/(1+(tan u)^2)...
Too me that just seems even more worse!
Then (LET: < be integral sign/ integrand)
[itex] = <1/(1+u) dr<br /> = <(1/(1+u)) (secu)^2 du<br /> = <((secu)^2/(1+u)) du[/itex]
Stuck...
and my latex is not working as well? Have I typed the wrong code?
1/(1+(tan u)^2)...
Stuck...
No no, put the two attempts together:
[tex]\int \frac{1}{1+r^2}\,dr = \int \frac{1}{1+\tan^2 u}\,\sec^2 u \, du[/tex]
You know your trig identities, right?
EDIT: Regarding LaTeX, that's because you're using the wrong tags. It should be tex or itex in the brackets, not latex.
Delete this. See below
Oh wait is the answer:
u because 1+tan^2 u = sec^2 u
then
[tex]= ∫1 du<br /> =u + C[/tex]
=tan(r)^-1 + C
Thank you for your help.
Mathpower said:
oh wait is the answer u because 1+tan^2 u = sec^2 u
then <1
If you mean
[tex]\int 1[/tex]
...then you're missing something.
Mathpower said:
=u
=tan(r)^-1 + C
Do you mean
[itex]\tan r^{-1} + C[/itex]
or
[itex]\tan^{-1} r + C[/itex]?
Opps... I meant [tex]tan<sup>-1</sup> r+C[/tex]
Thank you so much for your help. Sorry for being lazy.
