Integrating Arc Functions: \intx*arctg(1/x)dx
  • Thread starter Thread starter Dell
    Integrate parts
Dell
\intx*arctg(1/x)dx
i have such problems integrating arc functions, don't know why, but they never turn out right,,
by using
\intudv=uv-\intvdu
u=x
du=dx
dv=arctg(1/x)
v=[1/(1+(1/x)2)]*ln|x|
=[x2/1+x2]ln|x|
\intx*arctg(1/x)dx=x*arctg(1/x)-\int(x3ln|x|)/(x2+1)dx
now...
Your work going from dv to v is incorrect.
You have dv = arctan(1/x) (minor quibble: it should be arctan(1/x)dx), but from that you can't get to v = [1/(1 + (1/x)^2)]*ln|x|.
A possibility when you're doing integration by parts is arriving at an integral that's harder than the one you started with. That's usually a sign that what you picked for u and dv is not the right choice.
For this problem, I believe that the right choice is
u = arctan(1/x), dv = xdx
arctan(1/x)=u
du=[1/(1 + (1/x)^2)]*ln|x|*dx
xdx=dv
v=0.5x^2
is this correct?
this will also give me an integration harder than i started with
\intx*arctg(1/x)dx=0.5x^2arctan(1/x)-\int[0.5x^2/(1 + (1/x)^2)]*ln|x|dx
Dell said:
arctan(1/x)=u
xdx=dv
v=0.5x^2
is this correct?
For du, you're close, but you have the antiderivative of 1/x rather than its derivative. IOW, you have d/dx(1/x) = ln|x|, which is wrong.
Starting with u = arctan(1/x), and letting w = 1/x, we have
u = arctan(w).
So du = d/dw(arctan(w)) *dw = d/dw(arctan(w)) * dw/dx * dx
= 1/[1 + w^2] * (-1)/x^2 * dx (the factor before dx is where you made your mistake.)
= 1/[1 + (1/x)^2]* (-1)/x^2 * dx
\frac{-dx}{(1 + (1/x)^2)x^2}
= \frac{-dx}{x^2 + 1}
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
