Integrating the Complex conjugate of z with respect to z
Deevise
Im doing a bit of contour integration, and a question came up with a term in it am unsure of how to do: in its simplest form it would be
\int\bar{z}dz
where z is a complex number and \bar{z} is it's conjugate. Hmm i can't get the formatting to work out properly.. :S
If you are integrating over a circular contour of radius R then zz*=R^2, so z*=R^2/z. Otherwise you just have to take the contour and write it as z=(x(t)+iy(t)), so z*=(x(t)-iy(t)).
Well now i feel kind of stupid... its line intergration, not contour integration :P the question reads:
Evaluate the integral:
\int( \bar{z} +1 ) dz
L
Where L is the line segment from -i to 1+i.
normally i would just integrate and sub in start and end point, but i have totaly drawn a blank on what to do with the conjugate in this case...
Just treat it as a complex line integral. You can only 'sub in' endpoints if the function you are integrating is analytic and has an antiderivative. (z*+1) doesn't. Parametrize L as a function of t and integrate dt. Like I said, if you have z=(x(t)+iy(t)) then z*=(x(t)-iy(t)).
I think it's time i went to sleep... Yeh now that you mention the lack of anti-derivative i knew that. I think a good nights sleep will prepare me better for this exam than grinding my head into non-exsistant problems...
sorry to waste your time with inane questions lol... Thanks for the prompt responces.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
