Integrating (x^4+x^2)^0.5 form 3^0.5 to -3^0.5
  • Thread starter Thread starter ching5633
    Form Integrating
ching5633
Let x=tan u
dx=sec^2(u)*du
When x=3^0.5,u=pi/3
x=-3^0.5,u=-pi/3
S sec^2(u)d(sec u)
=1/3[2^3-2^3]=0
But it is wrong
ching5633 said:
Let x=tan u
dx=sec^2(u)*du
When x=3^0.5,u=pi/3
x=-3^0.5,u=-pi/3
S sec^2(u)d(sec u)
=1/3[2^3-2^3]=0
It's not clear why you chose this substitution, x = tan u, for this integral.
In any event, you have not shown what indefinite integral you obtained after making the substitution, so plugging in the limits to evaluate the definite integral is rather pointless.
Please show all of your work.
S(x^4+x^2)^0.5 dx
=S(x^2(x^2+1))^0.5
Let x=tan u
dx=sec^2(u)du
When x=(3)^0.5,u=pi/3
x=-(3)^0.5,u=-pi/3
=S(tan^2(u)(tan^2(u)+1)^0.5*(sec^2(u))du
=Ssec^3(u)tan(u)du
=Ssec^2(u)d(sec u)
=1/3*sec^3(u)
By substitution
Ans=0
Use the fact that the integrand is even to obtain <br /> \int_{-\sqrt{3}}^{\sqrt{3}} \sqrt{x^4 + x^2}\,dx = 2 \int_0^{\sqrt{3}} \sqrt{x^4 + x^2}\,dx<br /> which will avoid lurking sign errors (such as that if -\frac13\pi \leq u &lt; 0 then \sqrt{\tan^2 u} = |\tan u| = -\tan u.) Also, why not consider the easier u = x^2 instead of a trig substitution?
But why i can't calculate in this why ,I just dun know what is going wrong
ching5633 said:
S(x^4+x^2)^0.5 dx
=S(x^2(x^2+1))^0.5
Let x=tan u
dx=sec^2(u)du
x=-(3)^0.5,u=-pi/3
=Ssec^3(u)tan(u)du
=Ssec^2(u)d(sec u)
=1/3*sec^3(u)
By substitution
Ans=0
For this integral --
$$ \int \sqrt{x^4 + x^2}dx$$
-- the simplest thing to do is to factor x2 from the two terms in the radical, bringing out a factor of x, not x2 as you show.
## \sqrt{x^4 + x^2} \neq x^2 \sqrt{x^2 + 1}##
After you fix the mistake above, then use an ordinary substitution. You could use a trig substitution, but it's almost always better to use a simpler method than a more complicated one.
Edit: Because of the symmetric limits of integration, you need to bring out a factor of |x|, not x as I said earlier.
Such problems are always tricky, and you are well advised to ALWAYS look first at the "symmetry" of the problem, which in this case means that because your ##f(x) = \sqrt{x^2 + x^4}## is even, ##\int_{-a}^a f(x) \, dx = 2 \int_0^a f(x) \, dx##; more generally, for ##a,b > 0## it is best to write ##\int_{-a}^b f(x) \, dx = \int_0^a f(x) \, dx + \int_0^b f(x) \, dx##. Sometimes you can get correct answers by substituting in the limits at ##-a## and ##b##, but in other cases you get completely wrong answers, usually because formal algebraic manipulation of the antiderivative formula can give results that are incorrect over part of the ##x##-region (due to errors such as saying ##x = \sqrt{x^2}##, for example). Your antiderivative is ##(1/3)\sec^3 u = (1/3) (x^2+1)^{3/2}= F(x)##, and the derivative of ##F(x)## is ##F'(x) = x\sqrt{1+x^2}##. This is equal to ##f(x)## only when ##x \geq 0##. In fact, ##f(x) = |x| \sqrt{1+x^2}##, not ##x \sqrt{1+x^2}##. Since ##f(x)## is an even function its true antiderivative ##G(x)## should be an odd function. So, the correct antiderivative is
\int f(x)\,dx = (1/3) \text{sign}(x) (x^2+1)^{3/2} = (1/3) \text{sign}(u) \sec^3(u),
where
\text{sign}(w) = \begin{cases} 1, &amp; w &gt; 0\\<br /> -1, &amp; w &lt; 0<br /> \end{cases}<br />
Note added in edit: of course the Fundamental Theorem of Calculus applies, so the only issue is whether or not one's antiderivative formula ##F(x)## applies over the whole relevant range of ##x##. That is what one needs to be careful about.
if i substitute x^2=u
when x=(3)^0.5 , u=3
when x= - (3)^0.5,u=3
the integral will be from 3 to 3 which is equal to 0
it is [(x^2)*(x^2+1)]^0.5
sorry that I am not expressing this clear
This is nonsense. I already wrote out for you a complete explanation, but it seems you paid no attention at all to what I told you. Don't you get it? Carelessly substituting ##x^2 = u## without thinking can fail!. It is OK for ##x > 0##, but for ##x < 0## it gives the "wrong" ##du##, because when ##x < 0## and it increases by a little bit ##dx > 0##, then ##u## decreases and so we ought to have ##du < 0##. In other words, you need to use du = \text{sign}(x) 2 dx,
NOT ##du = 2 dx##. I keep making the same point over and over again: the antiderivative ##F(x)## is not just ##(1/3)(u+1)^{3/2} = (1/3)(x^2+1)^{3/2}##; it should be ##F(x) = \text{sign}(x)(1/3)(x^2+1)^{3/2}##. In terms of ##u## this would be ##\text{sign}(x)(1/3)(u+1)^{3/2}##, which looks a bit weird because it does not involve just ##u## alone.
I misread what you wrote. BTW, I like the other suggestions made in this thread better than my own. I corrected my earlier post to say that you can bring out a factor of |x|, rather than what I wrote about bringing out a factor of x.
Simply: \int\sqrt{x^4+x^2}dx=\int\sqrt{x^2(x^2+1)}dx=\int x \sqrt{x^2+1}dx
then by the simple substitution u = x^2+1 the integral transforms to:
\frac{1}{2}\int\sqrt{u}du = \frac{1}{2} \frac{u^\frac{3}{2}}{\frac{3}{2}}=\frac{u^\frac{3}{2}}{3}, the constant of integration was omitted because the original integral is definite.
Substituting back the value of u we conclude that: \int\sqrt{x^4+x^2}dx=\frac{1}{3}(1+x^2)^\frac{3}{2}.
The evaluation should be no problem at all.
About the factor |x|, I believe that it is not necessary and that you can only leave it as x. It is true that the square root of a positive number gives two answers, one positive and one negative both with the same magnitude. But we have to keep in mind that we are integrating a FUNCTION y(x)=\sqrt{x^4+x^2} And as you may see from the lack of negative sign of the root, the function is taking into account the positive part of y^2 =x^4+x^2 Therefore no absolute value is needed. Although, I have to admit that Vickson's answer is much more general.
This is oversimplified in light of the limits of integration of the original problem, and I admit to making the same mistake myself. Because the limits of integration are positive and negative, you have to incorporate the absolute value. Ray's posts explain this in detail.
No. The square root of a positive number is a function, which means it produces one result, not two. It is true that any positive number has two square roots, but, for example, ##\sqrt{9} = 3##, not ##\pm 3##.
Unfortunately, this is incorrect. The antiderivative of ##f(x) = \sqrt{x^4+x^2}## is NOT ##(1/3)(1+x^2)^{3/2}##; it is (up to a constant) ##F(x) = \text{sign}(x) (1/3) (1 + x^2)^{3/2}##. That last one is the form you must use if you want the fundamental theorem of calculus to give you the right answer from ##\int_{-a}^a f(x) \, dx = F(a) - F(-a)##. You made essentially the same error as the OP: the transformation ## u = x^2 + 1## is not monotone, and so leads to trouble when you integrate through ##x = 0##. As I said before, in integrating you need to use ##du = \text{sign}(x) 2 x dx##. More simply put: the antiderivative of an even function must be an odd function (plus a constant), but your claimed antiderivative is even.
