Integration and inverse trig functions
The discussion centers on integrating the function sinh(x)/(1+cosh(x)), with initial confusion about whether to use an identity. It is clarified that the functions in question are hyperbolic, not inverse trigonometric. A suggested change of variables is y = cosh(x), leading to a simpler form. The correct integral is identified as ln(1+cosh(t)) + C, with the derivative of the denominator matching the numerator. Overall, the conversation emphasizes the importance of recognizing hyperbolic identities in integration.
mavsqueen06
getting confused with integration of trig functions.
I am finding the integral of sinhx/1+coshx and I'm not sure how to start. should i use an identity?
help is appreciated!
possibly an identity of some sort?
Well the obvious chamge would be;
\frac{sinh(x)}{1+cosh(x)}=sinh(x) + tanh(x)
Which makes it a little easier.
EDIT: The functions are not inverse trig functions they are hyperbolic functions incidentally.
Or, change variables: y = cosh(x), dy = sinh(x)dx.
That equality isn't correct, although I'm pretty sure that that fraction works out to tanh(x/2) which might help a bit.
Do you see why
\int \frac{\sinh t}{1+\cosh t}{}dt =\ln\left(1+\cosh t\right) +\mathcal{C}
The derivative of the denominator is the numerator.
Daniel.
Thats a rather embarrassing schoolboy error that I wish I could blame on how late I was up last night, but its far too simple for that. :blushing:
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 18 ·
