Integration by substitution problem
In summary, integration by substitution is a technique used to solve integrals by replacing the variable with another variable or expression. It is useful for solving integrals that cannot be solved using other techniques and for simplifying difficult integrals. It is typically used when the integral contains a function that can be simplified by replacing the variable with another expression. The process for solving an integration by substitution problem involves identifying the function to be replaced, choosing a suitable substitution, finding the derivative of the substitution, substituting the new variables into the integral, and then solving the resulting integral. Common mistakes to avoid when using integration by substitution include forgetting to change the limits of integration and ensuring that the substitution is valid and the resulting integral can be easily solved.
madmike159
Using a suitable substitution find the solution to:
∫ (x+2)50(x+1)dx
I can't find a solution to this using substitution. Wolfram alpha give an answer that is too long to be calculated by hand. Can anyone work out the solution, or is there a mistake in the question which means it can't be solved?
[tex]Let\; u=x+2[/tex]
What do you get if you let u= x+ 2? That seems to me to be the obvious substitution. It is certainly not "too long to be calculated by hand".
1. What is integration by substitution?
Integration by substitution is a technique used to solve integrals by replacing the variable with another variable or expression. This allows us to simplify the integral and make it easier to solve.
2. Why is integration by substitution useful?
Integration by substitution is useful because it allows us to solve integrals that cannot be solved using other techniques. It also helps us to solve integrals that would be very difficult to solve using other methods.
3. How do you know when to use integration by substitution?
Integration by substitution is typically used when the integral contains a function that can be simplified by replacing the variable with another expression. This can also be identified by looking for a pattern in the integral, such as a function and its derivative.
4. What is the process for solving an integration by substitution problem?
5. Are there any common mistakes to avoid when using integration by substitution?
One common mistake to avoid when using integration by substitution is forgetting to change the limits of integration after substituting in the new variables. It is also important to check that the substitution is valid and that the resulting integral can be easily solved.
