Integration, complex roots and radians
shan
The first one, integration, I just want to check my answer.
\int \frac{1}{64} (\cos6\theta + 6\cos4\theta + 15\cos2\theta + 20) = \frac{1}{64} (\frac{\sin6\theta}{6} + \frac{6\sin4\theta}{4} + \frac{15\sin2\theta}{2} + 20\theta + c
I just wasn't sure if the integral of a constant wrt theta was constant*theta.
The complex roots question:
z^5 - i = (z-w1)(z-w2)(z-w3)(z-w4)(z-w5) = 0
Show that w1 + w2 + w3 + w4 + w5 = 0
From what our lecturer told us, -\prod_{1} = 0 so the sum of the roots = 0. I don't really understand this though :confused:
The radians problem... is basically because I don't know how to express radian in decimals into pi radians. [As part of an answer for coshz = 2i] I want to express the argument of 2 \pm \sqrt{5} which would be \tan^{-1} \sqrt{5}/2.
In case you want to know, I found z = log(2 \pm i\sqrt{5}) = ln|2 \pm i\sqrt{5}| + i arg(2 \pm i\sqrt{5})
I just need help finishing up the question :)
Do you mean...?
\int 0 \ d\theta = \mbox{const}_{1} \cdot \theta + \mbox{const}_{2}
If so, then it's simply wrong, unless \mbox{const}_{1}=0 which doesn't make any sense to write in the first place...
For the second problem, couldn't u use a formula due to Viète...?
Daniel.
For the roots one, try writing i as i = e^{\frac{i\pi}{2}+2\pi ni} and taking the fifth root of that. Then you can sum a geometric series to give you the answer.
dextercioby said:
Do you mean...?
oops sorry, I missed out a 20 in the integral so I'm asking if
\int 20 d\theta = 20\theta
I have never heard of this forumla?
And also, AlphaNumeric, could you explain why you suggested i = e^{\frac{i\pi}{2}+2\pi ni}??
z^{5} = i
You're looking for the 5 solutions of this equation, you're \omega_{1} to \omega_{5}
They are clearly of modulus 1, and complex, so you'll have \omega_{n} = e^{it} for some t you need to find. They are easy to find if you write i in for form I suggest.
z^{5} = e^{\frac{i\pi}{2}+2\pi n i}
Take 5th roots to get
z = e^{\frac{i\pi}{10}+\frac{2\pi n i}{5}
Usually express arguments in the range 0 to 2pi, so find the values of n which give you an argument in that range. n=0,1,2,3,4 will give you that, giving you roots
w_{1} = e^{\frac{i\pi}{10}}
w_{2} = e^{\frac{i\pi}{10}+\frac{2\pi i}{5}} = e^{\frac{5i\pi}{10}} = e^{\frac{i\pi}{2}} = i
etc
There's your 5 roots. Now you want to show they sum to zero. Well there's 5 of them and they are in geometric series, and you know how to sum those. The general formula is
S_{n} = a\frac{r^{n}-1}{r-1}
In this case r = e^{\frac{2\pi i}{5}}, so r^{5} = 1, and so S_{n} = 0.
ok, thanks for your help alphanumeric, it's a little easier to see why it is true that way.
For a more graphical representation for why it's true, think about an Argand diagram. If you've the equation z^{n} = k for any complex k, then the roots will be centred about the origin in a circle spread at an angle \frac{2\pi}{n} radians apart from one another. You can see this from writing k = re^{i\theta} (as I did for i) and repeating that method.
The average value of the n roots will be their sum divided by n. Geometrically, this is the centre of the circle, the origin. Therefore they sum to zero.
As an example, consider z^{n} = 16. Solutions are 2, -2, 2i, -2i. Plot them in the complex plane and you'll see they lie on a circle radius 2, with the circle centred on the origin.
I hope that helps you're understanding a bit :smile:
