Integrating: \frac{1}{(x^2+1)^2}
  • Thread starter Thread starter sara_87
    Integration
The discussion centers on integrating the function 1/(x^2+1)^2. Participants suggest that partial fractions are not suitable due to the form of the integrand, and recommend using trigonometric substitution instead. Specifically, substituting x with tan(theta) is advised, as it simplifies the integral involving the sum of squares. The conversation also touches on how to visualize the substitution using a right triangle to identify the sides and hypotenuse. Overall, trigonometric substitution is highlighted as an effective method for this type of integral.
sara_87
How do i integrate:
\int\frac{1}{(x^2+1)^2}
The answer is:
\frac{1}{4}(\frac{-2x}{x^2-1}-log(x-1)+log(x+1))
I don't know which method to use.
The answer you posted is correct if the integrand is 1/(1-x^2)^2. Is that what you meant? If so, try partial fractions.
Im sorry, the question is correct but the answer is:
1/2[x/(x^2+1)+arctan(x)]
here partial fractions won't work because i will still have a term with (x^2+1)^2 in the denominator
Have you tried a trig substitution? tan (theta) = x would be a good one to start with.
Ok, then it's a trig substitution. Like x=tan(t).
how did you know what substitution to make??
Draw a right triangle and label the sides and hypotenuse according to the expression in your integral. Since you have x^2 + 1, that corresponds to the hypotenuse. Label the side opposite your acute angle as x, label the base as 1, and label the hypotenuse as sqrt(x^2 + 1). So tan(theta) = x/1, and sec^2(theta)d(theta) = dx. Use these two equations to completely convert you integral from expressions in x and dx to ones in theta and d(theta).
If you're asking how did we know to make a trig substitution, they are good bets when you have factors involving the sum or difference of squares, such as sqrt(x^2 + a^2), sqrt(a^2 - x^2), or sqrt(x^2 - a^2).
what if we have (5+x^2)^2 in the denominator?
Label the opposite side as x and the base as sqrt(x), so tan(theta) = x/sqrt(5)
thank you
  • · Replies 105 ·
  • · Replies 19 ·
  • · Replies 22 ·
  • · Replies 54 ·
14K
