Integration using an Abel transform
|mathematix|
Find the following integral:
\int \frac{e^{x}}{\sqrt{(1+e^{2x})(1-e^{4x})}}dx
I changed the integral to: \int \frac{e^{x}}{(1+e^{2x})\sqrt{(1-e^{2x})}}dx
The let u=e^x
The integral becomes: \int \frac{du}{(1+u^{2})\sqrt{(1-u^{2})}}
I can do this the long way, such as on wolfram alpha but I want to use an Abel transform so let u=\sqrt{1-u^{2}}'
\sqrt{1-u^{2}}'=-\frac{u}{\sqrt{1-u^2}} \therefore v^{2}=\frac{u^{2}}{1-u^{2}}
du=\frac{dv}{\sqrt{1-u^{2}}}
The integral becomes: \int \frac{dv}{1-u^{4}}
I need to somehow get rid off the u and get the integral in terms of v so how can I do that?
u2 = 1 - v2, no?
haruspex said:
u2 = 1 - v2, no?
How do you get that?
Maybe I misunderstood your substitutions. This doesn't seem to be consistent:
|mathematix| said:
u=\sqrt{1-u^{2}}'
Did you mean v=\sqrt{1-u^{2}}'? If so, u2 = v2/(1+v2)
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
