Integration using Beta and Gamma Functions
200 replies · 32K views
ZaidAlyafey said:
Seems correct. Let us verify it by taking the limit as $x \to 1$.
What do you get ?
Does it agree with the value returned by wolfram.
The issue is with taking the limit.
$\displaystyle lim_{x\to1} \log(1-x)$ does not exist.
Olok said:
$$\sum_{k=1}^{\infty} \frac{x^{k+2}}{(k+1)(k+2)^3} = -Li_2(x)+ x - x\log(1-x) + \log(1-x) + 2x - \frac{x^2}{8} - Li_3(x) $$
Take limits of both sides. Don't distribute the limit until you are sure the limit exists.
$$\lim_{{x}\to{1}} -Li_2(x)+ x - x\log(1-x) + \log(1-x) + 2x - \frac{x^2}{8} - Li_3(x)$$
$$= \lim_{{x}\to{1}} -Li_2(x) +(\log(1-x))(1 - x) + 3x - \frac{x^2}{8} - Li_3(x)$$
The more interesting case is $\log(1-x)\cdot(1-x)$
$$y = \lim_{{x}\to{1}} (\log(1-x)\cdot(1-x))$$
Let $u = 1-x$ as $x\to1$ we have $u \to 0$
$$y = \lim_{{u}\to{0}} \log(u)\cdot(u) = \lim_{{u}\to{0}} \log(u\cdot e^u)$$
$$e^y = \lim_{{u}\to{0}} 0$$
But then we are back to where we started with $\log(0)$
$$\lim_{u \to 0} u \times \log(u) = \lim_{u \to 0} \frac{\log(u)}{\frac{1}{u}} $$
By L'Hospital rule the limit goes to 0.
That is very nice, but the denominator is not indeterminate is it? $1/0$ is not indeterminate is it?
$$= \lim_{{x}\to{1}} -Li_2(x) + \frac{23}{8} - Li_3(x)$$
$$= -\zeta(2) + \frac{23}{8} - \zeta(3)$$
Then
$$ \sum_{k=1}^{\infty} \frac{x^k}{(k+1)(k+2)^3} = -\frac{Li_2(x)}{x^2}+ \frac{1}{x} - \frac{\log(1-x)}{x} + \frac{\log(1-x)}{x^2} + \frac{2}{x} - \frac{1}{8} - \frac{Li_3(x)}{x^2}$$
Then we need to integrate:
$$\int_{0}^{1} -\frac{Li_2(x)}{(1-x)x^2}+ \frac{1}{(1-x)x} - \frac{\log(1-x)}{x(1-x)} + \frac{\log(1-x)}{(1-x)x^2} + \frac{2}{(1-x)x} - \frac{1}{8(1-x)} - \frac{Li_3(x)}{(1-x)x^2} \,dx$$
This is the most difficult part of all. Especially because if this is split up, a lot of it does not converge.
out of curiosity: could we use complex analysis to solve the sum we had? Also, can you also help me through some complex analysis, and contour integration? I am quite interested, but I don't have means to learn it except MHB. Help will be appreciated! =)
The limit is of the form $\frac{\infty}{\infty}$. which can be solved by L'Hospital rule.
I guess this will be complicated , at least you tried :) . Why don't we stick to the solution using Harmonic numbers ?
Of course.I 'll answer this question in the other thread.
But how do we use that formula?
$$\sum_{n=1}^\infty \frac{H_n}{n^q}= \left(1+\frac{q}{2} \right)\zeta(q+1)-\frac{1}{2}\sum_{k=1}^{q-2}\zeta(k+1)\zeta(q-k)$$
Lets consider $n = \displaystyle \sqrt{k+1}$
Then the lower limit will be
$k = 0$
Nevermind, I just realized the $H_n$ won't fit properly... Wow, this is difficult.
Ok , I will give you quick exercise
Find
$$\sum_{k\geq 0}\frac{H_k}{(k+1)^2}$$
Find
Ok.
Let $n = j+1$
$$\sum_{j=0}^\infty \frac{H_{j+1}}{(j+1)^2}= \left(1+\frac{2}{2} \right)\zeta(3)-\frac{1}{2}\sum_{k=1}^{0}\zeta(k+1)\zeta(3-k)$$
$$\sum_{j=0}^\infty \frac{H_{j+1}}{(j+1)^2} =
\sum_{j=0}^\infty \frac{H_{j} + \frac{1}{j+1}}{(j+1)^2} = \sum_{j=0}^\infty \frac{H_{j}}{(j+1)^2}+ \sum_{j=0}^{\infty} + \frac{1}{(j+1)^3}$$
Originally, the formula states:
$$\sum_{n=1}^\infty \frac{H_n}{n^q} = \sum_{n=0}^\infty \frac{H_n}{n^q} - 1$$
Then
$$\sum_{n=1}^\infty \frac{H_j}{(j+1)^2} = \sum_{n=0}^\infty \frac{H_j}{(j+1)^2} - 1 = (2)\zeta(3) - \frac{1}{2}(indeterminate)$$
I checked W|A, the sum involving the $q-2$ is indeterminate, which is bad news.
Olok said:
Ok.
Let $n = j+1$
Then
By definition if the upper index of the sum is 0 then the sum is 0.
Then why does W|A return it as indeterminate?
W|A can't solve it because the lower index is greater than the upper index.
So we have to add the following constrains $q>1$ and when $q=2$ the series is equal to 0. It is just a constrain that we defined on that particular case.
Any way, Let us assume that we can't find the summation when $q=2$ so we have to find
$$\sum_{k\geq 1} \frac{H_k}{k^2}$$
Can you think of a way to evaluate it without using that formula ?
Not really. I suppose the formula is the best way, and I suppose by definition the sum is $0$.
$$\sum_{n=1}^\infty \frac{H_j}{(j+1)^2} = \sum_{n=0}^\infty \frac{H_j}{(j+1)^2} - 1 = (2)\zeta(3) - 0 - 1 = 2\zeta(3) - 1$$
Hint :
use that
$$\int^1_0 \frac{1-x^n}{1-x}\,dx = H_n$$
ZaidAlyafey said:
Hint :
use that
That is what I did a while ago (with the other sum) and it became a mess as you saw.
$$\sum_{k=1}^{\infty} \frac{H_k}{k^2}$$
$$H_k = \int_{0}^{1} \frac{1-x^k}{1-x} \,dx$$
$$S = \int_{0}^{1} \frac{1}{1-x} \sum_{k=1}^{\infty} \frac{1-x^k}{k^2} \,dx$$
Assuming the parts of the sum are convergent we get:
$$S = \int_{0}^{1} \frac{1}{1-x} \left(\zeta(2) - \sum_{k=1}^{\infty} \frac{x^k}{k^2}\right) \,dx$$
$$S = \int_{0}^{1} \frac{1}{1-x} \left(\zeta(2) - Li_2(x)\right) \,dx$$
$$S = \lim_{{x}\to{1}} -\zeta(2)\log(1-x) - \int_{0}^{1} \frac{Li_2(x)}{1-x} \,dx$$
The Li_2(x)/(1-x) is the hard part. Integration by parts or some other strategy?
The limit doesn't exist so you cannot separate the two integrals because they are divergent as I said previously.
$$Li_2(x)+Li_2(1-x) = \zeta(2)-\log(x)\log(1-x)$$
$$\zeta(2)-Li_2(x) = Li_2(1-x)+\log(x)\log(1-x)$$
$$S = \int_{0}^{1} \frac{Li_2(1-x) + \log(x)\log(1-x)}{1-x} \,dx$$
Assuming this integral is convergent, I suppose can split this.
$$S = -Li_3(1-x)]_{0}^{1} - \text{problem}$$
Okay, this is depressing.
And very hard.
Try integration by parts , don't quite so easily.
NEW IDEA!
$\log(1-x)\log(x) = -Li_2(1-x) - Li_2(x) + \zeta(2)$
$$S = \int_{0}^{1} \frac{-Li_2(x) + \zeta(2)}{1-x} \,dx$$
First the antiderivative:
$$S = (\zeta(2) - Li_2(x)) + \int \frac{\log^2(1-x)}{(1-x)} dx$$
Let $\log(1-x) = u \implies du = \frac{1}{1-x}$
$$S_{antiderivative} = (\zeta(2) - Li_2(x)) + \frac{\log^3(1-x)}{3}$$
$$S = \lim_{{x}\to{1}} -Li_2(x) + \frac{\log^3(1-x)}{3}$$
Wait, does this limit exist?
Olok said:
NEW IDEA!
I don't understand how you got that. Moreover , S shouldn't be used twice since the first is definite and the second is indefinite integral.
I will need some help. Can you start me off on the integral? I can't think anything that will help right now.
ZaidAlyafey said:
Here is the approach.
Oh I see.
How is
$$\int_{0}^{1} \frac{\log(1-x)\log(x)}{x} \,dx = \int_{0}^{1} Li_2(x)/x \,dx$$
I believe $\log(1-x)\log(x) = -(Li_2(x) + Li_2(1-x)) + \zeta(2)$
Olok said:
Oh I see.
How is
Try integration by parts where I used that
$$Li_2(x) =- \int^x_0 \frac{\log(1-t)}{t}\,dt$$
I see.
But how does this all relate to the original sum?
Olok said:
I see.
Which original sum ? Isn't the question how to solve
$$\sum_{n=1}^\infty \frac{H_n}{n^2}$$
without using the formula ?
No, the one for the integral.
It was just an exercise to know how to solve Euler sums without using the formula.
How how can you solve:
$$\sum_{n=1}^{\infty} \frac{H_n}{(n+1)^2}$$
With the use of the formula?
Please, will you show me this example, and I can do the sum for the integral.
Look at this answer.
