Interesting Derivative Proof Question
14 replies · 2K views · last reply
Amad27
I recently searched around SE, and found:
http://math.stackexchange.com/questions/1142546/how-to-solve-this-derivative-of-f-proof
Below
The answer is interesting.
"A function given that $$f(x)=f''(x)+f'(x)g(x)$$ could be an exponential function, sine, cosine , quadratic polynomial or $$f\equiv0$$. So we can say that the function is a continuous function $\in C^2$.
The right negation is that $$f(x)\ge0 , \in (a, b)$$ and exist a point c | $$f(c)>0$$.You have that $$f''(x_1)\ge0$$ (the function in that point is convex) so in that point you have a minima so there are two case
1. $$f(x_1)<0$$ (obviously contradiction)
2. $$f(x_1)=0$$ (it's impossible because this imply that f(x) = 0)
Analog for the other case"
But how does $$f''(x_1) > 0$$ show that $$f(x_1) < 0$$? I don't understand the contradiction for #1??
Thanks!
The proof is saying that if f is not identically 0, then it must attain its maximum (or minimum) at x_1 in (a, b). And f''(x_1) = f(x_1) . But, using the second derivative test, if f(x_1) > 0, then we have a local minimum and if f(x_1) < 0, we have a local maximum. Contradiction.
Finding this strange. This should generate an infinite number of zeroes in the interval?
But how is that a contradiction and to what?
It's basic calculus. If f(x_1) > 0, how can that be a local minimum?
$$f(x) = x^2 + 1$$?
It has a minimum f(x_1) > 0?
Amad27 said:
$$f(x) = x^2 + 1$$?
We're not talking here about an arbitrary function. We're talking about one that meets the key criteria stated in the problem. The first of these is that f(x) = 0 at two distinct points. The second criterion is that f(x) = f''(x) whenever f'(x) = 0.
If such an f has a minimum it must be < 0. And f'' must be < 0 at that point. But, f'' < 0 implies it's a local maximum. That's the contradiction.
Ok, this is starting to make sense. The only part I do not understand is.
"If such an f has a minimum it must be < 0"
Why does this have to be true? Thanks!
Amad27 said:
Ok, this is starting to make sense.The only part I do not understand is.
To be more precise, the proof was:
If f(x) < 0 for some x in (a, b), then f attains its absolute minimum on (a, b).
And, if f(x) > 0 for some x in (a, b), then f attains its absolute maximum on (a, b).
But I am not asking what the question asked? I was asking,
How if f(x) < 0 it is a contradiction to have f"(x) > 0 ??
It isn't! Lots of functions have that property. But NOT the one in the question which meets certain criteria.
Do you not understand that a proof may apply to a function with certain properties, but not to all functions?
I do understand it.
But can you show that for our function it is a contradiction that,
if f(x) < 0 tthen the contradiction is to have f''(x) > 0??
Amad27 said:
I do understand it.
That's not correct either. We have f(x) < 0, f'(x) = 0 and f''(x) = f(x) < 0.
Yes but how will it be a contradiction?
Is the misunderstanding here that Amad is trying to prove a statement true by contradiction, while PeroK has proved it false by contradiction?
Perhaps the problem has been wrongly copied or misunderstood, for which there are other indications.
Also I saw earlier without even looking at the posts that if a function is such that between any two zeroes it has another zero, then it will have an infinite number of zeroes. Which is not impossible, but it would be a funny function to have an exercise on at this level.
