Is this Trig Identity really an identity?
In summary, the textbook states that the identity 1-((sin^2x)/(1+cos x))= cos x is a true identity, but it is not. The identity 1- cos x = (sin^2x)/(1+cos x) is a true identity, but it is not the same as the textbook's identity.
kuahji
394
The textbook states something along the lines as prove the identity.
1 - ((sin^2x)/(1+cos x)) = cos x
If you want you an work this out algebraically relatively easily to get cos x = cos x. But what if you put pi back into the original equation? You get 1 - undefined = cos x. So I graphed the two & the graphs looked the same, except the left hand side had a hole at odd multiples of pi. I showed the professor & asked him if it was still an identity. He looked in the solutions manual & its marked an identity & said he'd have to look into it further. Its been a couple of days & was just curious, it just doesn't seem to be a true a identity. What do other people think?
My guess at the way to "fix" this problem is to examin the left and right hand limits at the "holes" you should find that the limits are equal, therefore you can "fill" tbe hole with the limit value.
No, you don't. The right hand side can't be cos x, because [itex]x= \pi]. What you get is "1- undefined= -1"! Of course, it is NOT true that 1- ((sin^2 2x)/(1+ cos x))= cos x. Because the left side is not defined for [itex]x= \pi[/itex] while the right hand side is defined. Exactly WHAT were you supposed to prove? The "identity" you give is not correct.
The textbook says "verify each identity." In the solutions manual the problem is shown as a true identity, & the left side does break down to cos x.
Step 1
(1 + cos x - sin^2 x)/(1 + cos x)
Step 2
(cos x + cos^2 x)/(1 + cos x)
Step 3
cos x(1 + cos x)/(1 + cos x)
cos x = cos x
All I was really asking is if it was still an identity because the professor said he wasn't sure. The solutions manual breaks it down just like that (w/a few more steps shown). Does that make sense?
1 - (sin^2 x)/(1 + cos x) = cos x
1 - cos x = (sin^2 x)/(1 + cos x)
(1 - cos x)(1 + cos x) = sin^2 x
1 - cos^2 x = sin^2 x
Nonetheless, it can't be an "identity" because there are values of x for which the right hand side is defined but the left hand side is not (in its original form).
What do you define to be an "identity"? That is not clear. Algebraically, the 2 sides equal for all values of x in which they are defined, which is very reasonable. Just as 1/x = 1/x for every x in which they are defined.
I use x/x=1 all the time. Which is a rather similar sort of identity. Doesn't excuse you from checking the case x=0 though.
No, they are NOT "equal for all values of x in which they are defined". The right hand side is defined for [itex]x= \pi[/itex] while the left side is not. They are equal for all values for which BOTH sides are defined but that is not enough to make the two functions equal. What is true is
[tex]1- \frac{sin x}{1+cos x}= cos x[/tex]
for all x except odd multiples of [itex]\pi[/itex].
That is the same as saying that
[tex]\frac{x^2- 1}{x- 1}= x+ 1[/tex]
for all x except x= 1. The two sides are different functions because they have different domains and so are not equal.
What is an interesting trig identity?
An interesting trigonometric identity is an equation involving trigonometric functions that holds true for all values of the variables involved. These identities are useful in solving various mathematical problems and are also intriguing from a mathematical perspective.
What are some examples of interesting trig identities?
Some examples of interesting trig identities include the Pythagorean identity (sin^2x + cos^2x = 1), the double angle identity (sin2x = 2sinxcosx), and the sum and difference identities (sin(x+y) = sinxcosy + cosxsiny).
How can I use interesting trig identities in my work as a scientist?
Trigonometric identities are often used in scientific fields such as physics, engineering, and astronomy to model and solve various problems. They can also be used in data analysis and signal processing to simplify complex calculations.
Are there any tips for remembering trig identities?
One helpful tip is to understand the fundamental relationships between the trigonometric functions and how they relate to each other. You can also create flashcards or practice problems to help you memorize the identities.
What is the process for proving an interesting trig identity?
The process for proving a trigonometric identity involves using algebraic manipulation and properties of trigonometric functions to simplify one side of the equation until it is equal to the other side. This can involve using known identities, substitution, or other techniques. It is also important to keep in mind that the equation must hold true for all values of the variables involved.
  • Calculus
