Interference - Finding distance between slits
  • Thread starter Thread starter mattbonner
    Interference
To find the spacing between the center of the slits (D), the relationship Δy = λL/D is used, where Δy is the spacing between successive nodes, L is the distance from the slits to the screen, and λ is the wavelength. The slope of the Δy vs. L graph can be equated to λ/D, allowing for the calculation of D if λ is known. The discussion confirms that using the slope in this manner is the correct approach. Understanding the relationship between these variables is crucial for solving the problem. This method effectively connects experimental data with theoretical principles in interference patterns.
mattbonner
A laser is shone through a set of slits and onto a screen.
I have a Δy vs. L graph plotted, where Δy is the spacing between successive nodes, and L is the distance from the slits to the screen. I'm supposed to find the spacing between the center of the slits. The value of λ is given.
Δy = λL/D
D is the spacing between the center of the slits
I have the slope, but I don't know where to go from there...
I'm thinking that the slope will be equal to λ/D? and if I know λ, then I can calculate D. Not sure if this is the right way to go though.
Yes, that's right.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
