Interpreting BLDC motor spec sheet
  • Thread starter Thread starter Controlnoob1
    Bldc Motor
The discussion revolves around interpreting a BLDC motor spec sheet, specifically regarding terminal resistance and inertia units. The terminal resistance listed as 0.06 Ω is confirmed to be Rphase, representing the resistance of each winding in the three-phase wye configuration. Additionally, there is clarification on the unit of inertia, which is given in kg cm², and its conversion to SI units of kg m² is discussed in relation to torque calculations. Understanding these specifications is crucial for accurate calculations of torque and motor performance. The conversation emphasizes the importance of correctly interpreting motor specifications for effective application.
Controlnoob1
Hi everyone, first time poster!
Im having trouble reading the spec sheet attached and want to confirm the values I am using for calculation of Tm and Te.
The 3 phase wye BLDC motor spec sheet lists
1. Terminal Resistance = R2ph = 0.06 Ω
So this is Rphase and not R(line to line)?
ie Rphase is the resistance of each winding/phase of the 3 phase wye network?
2. What is the correct unit of inertia since it affects both the units of Kt and torque T?
Load inertia is listed in (kg cm^2) ie in SI (kg m^2)
(kg m s^2) {dividing "kg m^2" by gravity g } makes sense since
"torque due angular acceleration T = angular acc * inertia"
Thank you for taking your time to read this!
Yes, that is how I would interpret it.
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
