Intersection of surface and plane.
The discussion focuses on parameterizing the vector function for the intersection of the plane y = 5/2 and the elliptic cylinder defined by the equation (x^2)/4 + (z^2)/6 = 5. The correct parameterization of the ellipse in the x-z plane is established as x = √20 cos(t) and z = √30 sin(t). This method ensures that the equation (x^2)/20 + (z^2)/30 = 1 holds true for all values of t, confirming the accuracy of the derived vector function.
  • Understanding of parametric equations
  • Knowledge of elliptic cylinder equations
  • Familiarity with trigonometric functions
  • Ability to manipulate algebraic expressions
  • Study the derivation of parametric equations for conic sections
  • Learn about the properties of elliptic cylinders
  • Explore graphing techniques for visualizing parametric equations
  • Investigate applications of parameterization in physics and engineering
Students in calculus or analytical geometry, mathematicians working with conic sections, and anyone interested in the applications of parameterization in three-dimensional space.
Jimmy5050
Parameterizing vector function for intersection of cylinder and plane
Problem asks us to find the vector function of the curve which is created when the plane y= 5/2 intersects the ellptic cyl. (x^2)/4 + (z^2)/6 = 5
I know its going to be an ellipse formed...
I took the given ellptic cyl. equation, and divided by 5 to get (x^2)/20 + (z^2)/30 = 1.
***I parameterized by using x=cos(t) and z=sin(t) and got ((cost)^2)/20 + ((sint)^2)/30 =1.
Now, by looking at examples that are somewhat similar, I could tell the answer by looking at number relationships. However, I am unsure of the true way to go about getting my final solution.
My "made up way" of solving was to set either x or z to zero before parameterizing.
My final answers are x=(sqrt[20])cos(t) y=5/2 z=(sqrt[30])sin(t)
I checked my answer using a graphing program, and it is correct, but I am just unsure about going about the TRUE way of solving once I get to the part labeled *** above.
Thanks.
Any takers? I'm sure I have the answer right, just not sure of the "correct" last couple steps to get to that answer so that I can show work properly.
This step seems flaky to me.
The correct parametrization is, I believe, x = a*cos(t), z = b*sin(t). Then you have
[tex]\frac{a^2 cos^2(t)}{20} + \frac{b^2 sin^2(t)}{30} = 1[/tex]
For this equation to be identically true for all t, it must be that a2 = 20 and b2 = 30, which makes the parametric form of the ellipse (in the x-z plane)
x = [itex]\sqrt{20}[/itex] cos(t)
z = [itex]\sqrt{30}[/itex] sin(t)
I think this is the right way to go about it.
  • · Replies 21 ·
