Path Integral QM: Intro and Forward/Backward Scattering
grzz
hello
I started to read ‘QFT in a Nutshell’ by A. Zee. In the introduction to the path integral formulation of quantum mechanics there is the story about a particle going through a series of screens with holes drilled through them. Then the number of holes in each screen is increased. This results in the spaces on the screen which are not yet drilled becoming very small.
My difficulty is this. The undrilled spaces are then so small that they themselves may act as obstacles thereby providing an amplitude of scattering the particles backwards. Am I complicating things by including this backward scattering together with the amplitude of forward propagation of the paticle?
Any help?
Thanks.
This is true even when the undrilled spaces are not small. For example, if we have a screen with a single hole, the entire rest of the screen has a nonzero amplitude of scattering the particle backwards.
Yes, at least for the simple version Zee is considering at this point in the book. The key is that, in the example given, we are evaluating the amplitude for the particle to go from a particular source, which has some location in space, to a particular detector, which has some other location in space. We are not considering the amplitude for the particle to go somewhere else, such as being scattered backwards and flying off to a place where we don't even have a detector.
(And even more strictly, it should be "location in spacetime", not just "location in space"--i.e., we are evaluating the amplitude for the particle to be emitted from the source at some particular time and detected at the detector at some other particular time.)
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
