Introducing LaTeX Math Typesetting
766 replies · 756K views
[itex]\frac{\mathbb{N}}{\mathbb{N}}=\mathbb{N}[/itex]why am I over here?
For some reason this image contains a lot of whitespace on my browser; the text is all on the right side of the message!
This LaTeX seems to be missing the Greek letter "omicron."
All LaTeX is "missing" this character. The Greek omicron is exactly the same as the Roman 'o,' and thus has no special \omicron command. Just use 'o.' It's the same story with \Alpha and \Rho and so on.
- Warren
Hurkyl,
I'm not exactly sure why that's happening. Apprently it's the \frac command that's doing it, coupled with the way I crop inline images. (Inline images are cropped differently from display-mode images, so that they appear at the right location vertically). I'll have to do some more thorough experimenting next time I'm on the site. In the meantime, don't inline \frac I guess.
You can also inline it manual-style like this: [tex]\mbox{ \Large $ \frac{\mathbb{N}}{\mathbb{N}}=\mathbb{N} $}[/tex]. Doing so renders the image as inline-mode, but crops the image as display-mode (meaning it may not appear at the right position vertically). It works, but that's a bit ridiculous. I'll look into it next time I get the chance.
- Warren
One should probably use [itex]\mathbb{N}/\mathbb{N}[/itex] style fractions in inline text anyways, but a bug is still a bug!
I agree with Hurkyl. fraction type [itex]\frac{\mathbb{N}}{\mathbb{N}}=\mathbb{N}[/itex] should only be used in equation ( or eqnarray), but while writing along with text we should use [itex]\mathbb{N}/\mathbb{N}[/itex]
cheers,
Nagaraj
VU3OGI is my HAM callsign
any ideas why this isn t working?
[tex] \begin{multline*}<br /> \tan^n \theta=\tan^{n-2}\theta \tan^2 \theta\\ =\tan^{n-2}\theta(\sec^2\theta-1)=\tan^{n-2}\theta\sec^2\theta-\tan^{n-2}\theta<br /> \end{multline*}[/tex]
Mainly because the environment is not called multiline, it's called multline (without the 'i'). Try this:
- Warren
oops... i m an idiot.
thanks chroot.
How do I make a script P, such as is typically used in the notation for a power set [itex]P(X)[/itex]?
Hi folks!
I'm just setting up a practice spot for myself here. Don't mind me. These will be changing/dissappearing as I get new thoughts, but feel free to watch my struggles.
[tex] M^2 = \left(<br /> \begin{array}{cc}<br /> M^2_{11} & M^2_{18}\\<br /> M^2_{18} & M^2_{88}<br /> \end{array}<br /> \right)[/tex]
[tex] M^2_{88} = \frac {1}{3} \left(4m^2_{K} - m^2_{\pi}\right)[/tex]
[tex] M^2_{11} = m^2_{\eta} + m^2_{\eta'} - M^2_{88}[/tex]
[tex] M^2_{18} = - \sqrt{(M^2_{88} - m^2_{\eta})(m^2_{\eta'} - M^2_{88})}[/tex]
[tex] \tan\theta_{P} = \frac {M^2_{88} - m^2_{\eta}}{M^2_{18}}[/tex]
Dang this is freakin' cool!
[tex] \begin{multline*}<br /> \eta = \eta_{8}\cos\theta_{P} - \eta_{1}\sin\theta_{P}\\<br /> \eta' = \eta_{8}\sin\theta_{p} + \eta_{1}\cos\theta_{P}<br /> \end{multline*}[/tex]
[tex] \eta_{1} = \frac {u\bar{u} + d\bar{d} + s\bar{s}}{\sqrt{3}}, <br /> \eta_{8} = \frac {u\bar{u} + d\bar{d} - 2s\bar{s}}{\sqrt{6}}[/tex]
I just can't stop...
[tex] \nu_e[/tex]
[tex] \nu_e\bar[/tex]
[tex]\neq[/tex]
What would be the symbol for 'not equivalent to' and how would you represent it in latex?
Wouldn't it just be a crossed equivalent sign (or is that stronger than 'not equivalent to'?)? which I can't seem to get that anyway.
[tex]\nequiv \notequiv[/tex]
thanks!
I was looking at a table of glyphs used in maths and it had that sign as 'not identical to' is that interchangable with 'not equivalent to' or can the sign mena both things?
Wow this is awesome, but is there a sperate program or way that I can do the Math Typesetting offline or find it as a standard software? I would like to be able to type out some mathematical notes for my self since my hand writing is a bit sloppy and my notebook becomes incoherent...
You can use MiKTeX if you use Windows. If you use Linux, your distro should already have TeX and LaTeX software.
im kinda slow, andim not that advanced, so I am tryin lil things. but i like this thing, ima be the only person in my class with a fully typed physics report.
[itex]f_{x}=f\cos\theta[/itex]
I installed it but how do I use it? Do I just go to notepad and type up and save it as a .dvi file?
You type it up in a regular text file, then save it with a .tex extension. Then, you need to compile it by typing "latex file" (no quotes, in Windows, at a DOS prompt, in the directory where the file is saved), where file.tex is the thing you just saved. This will generate a DVI file. With Miktex, you can then type "yap file", which opens the Yap DVI viewer.
Alternatively, you can output to a PDF file by typing "pdflatex file" at the prompt.
Unfortunately, LaTeX has a rather stiff learning curve.
Fortunately, there are 4.9 gabillion webpages to help you out. Just google around for some sample documents.
- Warren
can we make feynman diagrams?
[tex]\begin{fmfchar*}(40,25)<br /> \fmfleft{em,ep}<br /> \fmf{fermion}{em,Zee,ep}<br /> \fmf{photon,label=$Z$}{Zee,Zff}<br /> \fmf{fermion}{fb,Zff,f}<br /> \fmfright{fb,f}______<br /> \fmfdot{Zee,Zff}<br /> \end{fmfchar*}[/tex]
Not yet. I have considered adding the feynmf package, but, since it uses metafont, it would involve adding an additional stage to the image generation process. I'm not sure I want to go through all that trouble!
- Warren
- Warren
stop being so lazy!
just kidding, chroot.
actually, i just tried to get feynmf working on my computer, and failed. grr...
so i can sympathize.
Just wondering!
[tex]\ddot{\smile}}[/tex]
I seem to be having a problem generating "n choose m"
Let's see if it works better here
[tex]x=({\colv{n}{m}})[/tex]
Did that work?
What's this? The sample I used as my template before just used the \colv command to line up two expressions over each other, but if I click the sample above that, I se a \newcommand statement that uses an array construct. Aha! Let's see if I can do that myself, as in
[tex]\newcommand{\colv}[2] {\left(\begin{array}{c} #1 \\ #2 \end{array}\right)}X = {\colv{n}{m}}[/tex]
I hope that does the trick!
Yes! Hallelluah! Now, let's see if that new command works as the first nonprintable line in a post and applies throughout it.
no, it's a transient macro. It has to go on every tex statement and gets forgotten on the /tex. Too bad.
[tex]\newcommand{\colv}[2] {\left(\begin{array}{c} #1 \\ #2 \end{array}\right)}\colv{n}{m} = \frac{n!}{(n-m)!m!}[/tex]
[tex]\newcommand{\colv}[2] {\left(\begin{array}{c} #1 \\ #2 \end{array}\right)}\colv{n}{m} = \colv{n}{n-m}[/tex]
Plus, it is so easy to mistype a brace as a parentheses! I hate it when that happens.
But, at least that's one problem down. Onwards to the prefix superscript next.
If you want choose notation, just use
[tex]\binom{n}{m}=\binom{n}{n-m}[/tex]
This is a test - and a place to make experimental edits. I'll remove most of this post and post it with explanatory comments in the general math folder later.
Editing a long post doesn't always work (get a lot of "website not responding" errors). Let's see if shortening the post helps.
tbd
