Introductory Astronomy Question - function help
The discussion revolves around finding a new expression for the function b(x) by eliminating the variables lambda and T. The function is defined as b(x) = h^4 * c^3 * U(sub-lambda) / 2*(kT)^5, where U(sub-lambda) represents the Planck Blackbody Function. Participants suggest substituting a known expression for U(sub-lambda) into the equation to simplify it. The conversation emphasizes the importance of referencing textbook or lecture notes for the appropriate expression for U(sub-lambda). Overall, the focus is on the mathematical manipulation required to achieve the desired function.
Heisenberg.
The question asks to find a new expression for a function, by substituting suitable expressions for the elimination of lambda and T.
The function is:
b(x)= h^4 * c^3 * U(sub-lambda) / 2*(kT)^5
In this case:
U(sub-lambda)= U(sub-lambda)(lambda,T) - Planck Blackbody Function
x= lambda*k*T / h*c
I assume that there is some way to substitute some of the equations into the function - but I am at loss to see how - any help would be appreciated - Thank You
Were you given an expression for Uλ(λ,T)? Perhaps in your textbook or lecture notes ... I think the next step would be to substitute that expression into the RHS of your b(x) equation here.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
