Invariance of Domain: Showing U Open in Differential Geometry | Spivak Ch.1
  • Thread starter Thread starter Rasalhague
    Domain Invariance
Rasalhague
In the first volume of Differential Geometry, Ch. 1, Spivak states that if U \subset \mathbb{R}^n is homeomorphic to \mathbb{R}^n, then U is open. This seems obvious: \mathbb{R}^n is open in \mathbb{R}^n, so its pre-image under a homeomorphism f:U \rightarrow \mathbb{R}^n is open. The pre-image under f of \mathbb{R}^n is U. Therefore U is open in \mathbb{R}^n.
Why does Spivak not take this obvious route? Am I mistaken about it? Instead, he says that proof of the openness of U needs something called the Invariance of domain theorem.
This step is wrong. The correct conclusion from that information is
... therefore U is open in U.​
Ah, I see! And, of course, U must be open in U anyway, being a topological space; but the issue is whether U is open in \mathbb{R}^n. Thanks, Hurkyl.
I still don't get it. The IOD theorem is of the form "(A&B) implies C". Since f is a homeomorphism, B and C are true (f is 1-1 and continuous, and f is a homeomorphism). But this says nothing about A (U is open in R^n). (A&B) implies C" is consistent with A being true or false.
As an aside, does the theorem assume that f is onto and hence invertible, or is this implied by the antecedents?
Replace C with C&D. I believe you're correct that D is trivial, and it was strange to include it. However, C is still certainly nontrivial (the openness of V in ℝn).
A sphere as topological manifold can be defined by gluing together the boundary of two disk. Basically one starts assigning each disk the subspace topology from ##\mathbb R^2## and then taking the quotient topology obtained by gluing their boundaries. Starting from the above definition of 2-sphere as topological manifold, shows that it is homeomorphic to the "embedded" sphere understood as subset of ##\mathbb R^3## in the subspace topology.
