How Do You Find the Inverse of the Composite Function fh(x)?
To find the inverse of the composite function f(h(x)), where f(x) = 2x + 5 and h(x) = 1/x, the correct expression is f(h(x)) = 2(1/x) + 5, simplifying to 2/x + 5. To find the inverse, switch x and y in the equation y = 2/x + 5, resulting in x = 2/y + 5. The next step involves isolating y, which clarifies the mechanics of the transformation. If h(x) were altered to 1/x + 5, the resulting composite function would change accordingly to f(h(x)) = 2(1/x + 5) + 5, yielding a different expression. Understanding these transformations is crucial for accurately finding inverses of composite functions.
ghostbuster25
Just want to check that i am doing this question correctly.
f(x) = 2x+5 h(x) = 1/x , x \neq0
Find the inverse of fh(x)
So first i found the function fh(x)
2*1/x+5
then let y = 2*1/x+5 , x \neq0
now this is the bit i can't rememeber how to do, when i try and make x the subject do i need to multiply the 2 on the RHS as well as the y on the LHS?
if i multiply the 2 then i end up with f-1(x)=2x+5/x
If i don't i end up with f-1(x) = x+7
First of all, you do mean f(h(x)), and not fh(x), which to me looks like f(x)*h(x). Under that assumption...
f(h(x)) = 2/x + 5.
So, you have y = 2/x + 5..
To find the inverse, you usually just switch x and y, and solve appropriately.
I'll start with the first step: x = 2/y + 5
Can you carry it through from here?
I can now thanks :)
I see what you have done but I am not sure why 1/x becomes 2/x in this circumstance. I am just trying to understand the mechanics behind it so i can be fully aware. If h(x) was 1/x + 5 would it still be 2/x +5 or 2/x + 10?
your correct in your assumption, my teacher is poor and makes us write it fh(x) instead of f(h(x))
Whereever you saw x, you needed to replace with 1/x. So all you really have is instead of 2*x + 5, you have 2*(1/x) + 5.
If h(x) = 1/x + 5, and f(x) = 2x + 5 then you will actually have f(h(x)) = 2(1/x + 5) + 5 = 2/x + 15.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
