Inverse Laplace transform Help
4 replies · 3K views
Icy950
I couldn't figure the sol'n for this problem
Could somebody help?
Thanks a lot
Find the following Inverse Laplace transform
(L^(-1))*[1/(4s+1)]:frown:
Thanks a lot
That's almost direct from a table...
or are you doing these by hand?
I'm trying to do this by hand
Hopefully I can get some help
Thanks a lot
Well you will definitely need to show some work.
Also, you should check out LaTeX in the tutorial section. Then you can show your work as:
[tex]\frac{1}{4s+1}[/tex]
It might be easier for you to see the solution if you first divide everything by 4:
[tex]\frac{1/4}{s+1/4}[/tex]
Now it should be clear that:
[tex]L^{-1}(\frac{1/4}{s+1/4}) = \frac{1}{4}e^{\frac{1}{4}t}[/tex]
