Can you simplify this inverse trig problem?
In summary, you tried using the identity tan(2x) = 2tan(x) / (1-tan^2(x)) to solve for x in a cubic equation.
Kishlay
91
Inverse trig problem -- please help!
tanx+tan2x+root3tanxtan2x=root3
find x...
i have tried a lot and always ended with a complicated cubic equation...
please help me by giving me a another approach to the solution
I'd try using the tan(a+b) identity to reduce the equation into terms with tan(x) factors.
what is the root3 you mention? Is it some arbitrary constant?
yes I have tried the same thing as you have said
root3 is same as √3
find x...
Do you mean:
##tan(x)+tan(2x)+\sqrt{3}*tan(x)*tan(2x)=\sqrt{3}## ?
root3 is same as √3
and you tried using the identity tan(2x) = 2tan(x) / (1-tan^2(x))
and then collecting terms to create a cubic equation in tan(x) that's equal to zero.
so??
adjacent said:
Do you mean:
yes..
how did you typed it??
find x...
It is not enough to say what you have tried. You need to show us what you have tried.
adjacent said:
Do you mean:
yes... how did you typed it?
i have used the identity of tan(A+B)
then i simplified it and got a cubic equation in tanx
and i don't know how to solve a cubic...
i am a high school student :)
The PF website provides an advanced editor where you can enter mathematical expressions with subscripts, superscripts, summations, integrals...
Use the "Go Advanced" button to the right of the "Post Quick Reply" button next time.
Kishlay said:
yes..
Latex-Quote it and see how I've written it.You have to write
Code:
## and ##
around the sentence.
Code:
## and ##
ok...:)
So show us the cubic equation.
The goal of the PF forum is help you with your homework not do it for you.
No need to solve a cubic equation.
Notice that √3=tan(π/3)
You can rearrange the equation as
[tex]\tan(2x)(1+\sqrt3 \tan(x))=\sqrt3 - \tan(x) [/tex]
that is
[tex]\tan(2x)=\frac{\sqrt3 - \tan(x)}{1+\sqrt3 \tan(x)} [/tex]
Recall that
[tex]\tan(a-b)=\frac{\tan(a) - \tan(b)}{1+\tan(a) \tan(b)} [/tex]
ehild
Likes 2 people
i have got this equation
(tanx)3-3[itex]\sqrt{}3[/itex](tanx)2-3tanx+[itex]\sqrt{}3[/itex] =0
that is
Recall that
ehild
thanks...!
You are welcome:smile:
ehild
It had been done and very properly:biggrin:
ehild
What is an inverse trig problem?
An inverse trig problem is a type of mathematical problem that involves finding the angle measure given the ratio of sides in a right triangle. In other words, it is the opposite of a traditional trigonometry problem, which involves finding the ratio of sides given an angle measure.
What are the three main inverse trig functions?
The three main inverse trig functions are arctangent (atan), arcsine (asin), and arccosine (acos). These functions are used to find the angle measure in a right triangle when given the ratio of sides.
How do I solve an inverse trig problem?
To solve an inverse trig problem, you must first identify which inverse trig function to use based on the given ratio of sides. Then, use the inverse trig function on a calculator or use a trigonometric identity to solve for the angle measure.
Can an inverse trig problem have multiple solutions?
Yes, an inverse trig problem can have multiple solutions. This is because there are multiple angles that can have the same ratio of sides in a right triangle. When solving an inverse trig problem, it is important to consider all possible solutions.
What are some common applications of inverse trig functions?
Inverse trig functions are commonly used in fields such as engineering, physics, and navigation. They are also useful in real-life situations, such as determining the angle of elevation or depression in surveying or finding the distance between two objects using trigonometry.
