Inward Acceleration for Ununiform Slope
  • Thread starter Thread starter Mechanics
    Acceleration Slope
The discussion focuses on calculating the apparent instantaneous radius "r" for an object moving along an ununiform slope, specifically using the example function y=x^2-x. Participants clarify that "r" relates to the inward acceleration, which is derived from the normal acceleration component directed towards the curvature of the path. The normal acceleration is expressed as a_n = v^2/ρ, where ρ represents the curvature. There is confusion regarding the definitions of the components of acceleration, distinguishing between normal and tangential components. The conversation emphasizes the complexity of applying circular motion equations to non-circular paths.
Mechanics
I started doing some physics today for the first time since school got out a few months ago. The period of inactivity was painfully apparent throughout the attempt.
I'm trying to find the apparent instantenous "r" of an object moving along an ununiform slope where "r" is the radius of a circle that would have the same inward acceleration. Example of possible path: y=x^2-x.
I assume you are referring to the radius of a circle that would have the same acceleration as described by the equations of rotational motion? Is the example function representative of the displacement the velocity or the acceleration?
The function describes the vertical displacement, y, compared to the horizontal displacement, x.
Would'nt it be
r = \frac{V_{tan}^2}{a_{in}}
where one uses the tangential speed in the calculation?
I'm trying to find the equivalent "r" in terms of x and y for the acceleration. Yes, if it was a circle the acceleration would be v^2/r...but this surface we're talking about is not as nice as a circle.
What is this "inward" acceleration you are talking about? I thought you were talking about the normal acceleration component. The other component that goes with it is the tangential acceleration component. That is the components normal and tangential to the object's path.
The normal acceleration component is directed towards the inner curvature of the path and is given by
a_n = \frac{v^2}{\rho}
where \rho is the curvature of the path. Do you need to determine it for a given path?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
