Is 180 a Valid Solution for the Trigonometry Equation in Part B) ii?
  • Thread starter Thread starter Hypochondriac
    Trigonometry
The discussion revolves around verifying whether 180 is a valid solution for the trigonometric equation sin(2x) = 2 - 2cos(2x). The subject area is trigonometry, specifically focusing on the properties of sine and cosine functions and their relationships.
  • The original poster attempts to verify the solution by manipulating the equation and expresses confusion over the validity of dividing by sin(2x). Some participants discuss the implications of dividing by a trigonometric function that could be zero and the necessity to check for extraneous roots. Others suggest methods for verifying the solution.
The discussion is active, with participants exploring different methods to verify the solution of x=180. There is a recognition of the need to check the validity of solutions derived from equations, particularly when division by a trigonometric function is involved. Some guidance has been offered regarding how to approach the verification process.
Participants note that the interval for solutions is (0, 360), and there is mention of finding additional solutions as part of the problem. The original poster also indicates that part a of the question seems irrelevant to their current inquiry.
Hypochondriac
in part b) i of a question, i was asked to prove that (1-cos2x)/sin2x is equivilent to tanx and so i did.
then in part b) ii i was asked to varify that 180 is a solution of x for:
sin2x = 2 - 2cos2x
i took the 2 out; sin2x = 2(1 - cos2x) and saw similarities to part i,
so i divided by 2sin2x to get
(1-cos2x)/sin2x = 1/2
which using part i i deduced that tanx = 1/2
but 180 isn't the solution of this. (26.6 is)
where did I go wrong, was it because I divided through by a the 2sin2x when i shouldn't have?
in my https://www.physicsforums.com/showthread.php?t=165036" it was apparently ok to divide by a trig funtion, if this is the problem here why does it apply to this and not my other question
NB part a of the question seems irrelevant.
part b) iii however asks me to find the other 2 solutions, of which 26.6 is one of the answers
so how do i get to 180 and the other solution for part b) iii
It's ok to divide by a trig function unless in the end that trig function turns out to be zero. If you put 180 in sin(2x) you get zero. So the original equation has zeros that the divided equation does not. Eg. x*(x-1)=0 has the solutions 0,1. (x-1)=0 has only 1.
ok so as sin2x = 0 for x=180, when you divide it goes.
so if i can't do that then how do i varify that x=180
i've already found out how to get the other solution, i forgot to mention that the interval is (0, 360)
When you divide by something make a note to yourself to check in the end that the thing you divided by is not zero, and if it is zero, then check that it is not an extra root. So you need to solve both tan(x)=1/2 and sin(2x)=0 and then check if all such values are really roots. Ie substitute them into sin2x = 2 - 2cos2x.
To verify x=180 is a solution
LHS is sin(360)=0
RHS is 2 -2cos(360)=2-2=0
LHS=RHS so x=180 is a solution
to obtain x=180 as a solution
(1-cos2x)=(tanx)(sin2x)
sin2x=2(1-cos2x)
sin2x=2(tanx)(sin2x)
sin2x-2tan(x)(sin2x)=0
sin2x(1-2tanx)=0
sin2x=0 or 1-2tanx=0
ahh its all clear now, would either one of the above proofs for x=180 be valid as an answer or will the latter have to be shown?
Depends on the wording of the question
verify that x=180 is a solution of ... use the first method
show that x=180 is a solution of... use the second method.
