Is 3 Phase Power Essential for a Complete Education in Electrical Engineering?
Three-phase power is crucial for a comprehensive education in Electrical Engineering, particularly because it underpins the operation of large motors used in various applications like elevators and HVAC systems. The discussion highlights the importance of understanding the phase relationships, specifically that in the U.S., the phases are 120 degrees out of phase. While the student has a solid foundation in single-phase power, they seek resources that provide detailed explanations of three-phase power analysis without skipping steps. The conversation also touches on Wye and Delta configurations, which are essential for understanding motor operations in industrial settings. Overall, grasping three-phase power is vital for any electrical engineer, especially for those working with industrial motors.
samdunhamss
Hello, I am an Electrical Engineering student taking my second circuit analysis course. My program is actually very good and they explain things very well. My main concern is that none of my courses have covered or much less mentioned 3 phase power. My first question is simple: Are they skimping out on something that is imperative to a good education in the field of Electrical Engineering? My second question: Is there a good source that explains this concept in a clear and accessible manner?
A little background - I am well versed in calculus and differential equations and have a strong grasp on single phase power analysis. Despite this, I need material that explains the concept in explicit detail, I strongly dislike steps being skipped.
Any and all responses are greatly appreciated.
Of course 3 phase is important, basically every large motor in any building is a 3 phase motor. Elevators, HVAC, etc. If you have a good foundation on AC, all you need to know is the phases lead/lag each other by 90 degrees. Are you asking how a 3 phase motor works? Motors are the main reason you use 3 phase.
More than anything I'm curious about three phase power analysis. I knew motors operate on a polyphase basis. I guess I was just curious if there is a good text which covers circuit analysis with three phases? or would it be like have three sources out of phase with one another connected to a node?
3 phase in the U.S. operates with the three phases 120 degrees out of phase, not 90.
Averagesupernova is 100% correct, my mistake. If you draw out 3 sin waves 120 degrees apart you will see that they would maintain a stable rotation in a motor with poles 120 degrees apart as well.
connecting 3 phases to a node would be Wye operation, you would be well served to study Delta operation also. Industrial motors perform mostly in Delta. A frequency driven or soft start type motor is usually running in Delta. Older contactor run motors usually spin up in wye, then transfer to delta. You probably already knew this, but I figure it's worth mentioning. I wish I could be more help as to a source for analysis.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
