Is a complete graph meaningful ?
  • Thread starter Thread starter EddieCrash
    Complete Graph
A complete graph is a well-defined concept in Graph Theory, representing a graph where every pair of vertices is connected by an edge. The term "complete graph" is commonly used, despite initial confusion about its usage. It is characterized by having all possible edges between its vertices, making it isomorphic across different instances with the same number of vertices. Understanding this concept is essential for discussions in graph theory and related fields. The complete graph's significance lies in its structural properties and applications in various mathematical contexts.
EddieCrash
Is "a complete graph" meaningful ?
Mathematics news on Phys.org
Yes, it is. But where does the question come from?
I thought no one says "a complete graph", I also don't know what it is.
Thanks for your answer, bye
It has a well defined meaning in Graph Theory. But I don't know if that is what you wanted: the complete graph (with n vetices) is the one with all possible edges. They are all isomorphic, as graphs, so we can say 'the complete graph' with n vertices.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
