Programs Is a double major worth it? (Physics, chemistry)
Considering a double major for a career as a forensic scientist raises important points about employment prospects and the relevance of coursework. While a double major may seem beneficial, it’s crucial to recognize that lab technicians typically specialize in specific areas such as molecular biology, chemical analysis, or ballistics, rather than being generalists across multiple disciplines. The discussion highlights that pursuing a double major might not enhance job readiness if the focus is on mastering a particular skill set. The recommendation from the physics department to consider a materials science track may not align closely with forensic science, as materials science often leans towards engineering principles rather than forensic applications. Ultimately, while gaining additional knowledge is valuable, the practicality of a double major should be weighed against the demands of specialization in forensic science.
hawkeye295
Yes, another one of these threads. GET OVER IT! Just kidding LOL.
A few disclaimers: I do have a practical reason for considering a double major. A career path I have been strongly considering in the past two years is to become a forensic scientist (crime lab technician). Also, this isn't just a "CSI phase", because I've read several books and web-articles on the actual aspects of the career. Plus, I don't watch those shows anyway. Jeopardy! is my favorite.
It might be a bit naïve to think a double major gives you better employment prospects, but I honestly don't see why not in this case, considering both fields can be applied on the job (ballistics, toxicology, accident reconstruction, etc.)
Do you think all of the extra work would be worth it? I asked the physics department at the school I'm attending and they recommended the "materials science" track. I checked it out, and it seems like that's more of an engineering route.
If it's stupid and unrealistic, don't be afraid to say so. I can handle it. I'd be willing to settle with a different science or math related career.
Thanks everyone for your input.
Lab technicians only do one thing. They do molecular biology. They do chemical analysis. They do ballistics. They don't do all three. Your job is to carry out these analysis perfectly, because a lot of it depends on it. Therefore, you can't do one thing one day, then another the other. At your lab you are to be the expect in one or several related analysis methods. If people rotate, no one knows anything.
Engineering is completely unrelated. You then will be building stuff, solving engineering problems, rather than doing lab analysis.
If you already exactly know what you want to do, combining two science degrees are never worth it. But then again, people here sometimes seem to have a different definition of a 'double major' or 'double degree'. To me it means you get two degrees, but you get some shortcuts in having to do only one thesis or internship and shared courses of course cut down the ECTS from 360/6 years to something more manageable. Others seem to mean to just get the same amount of credits, but just divide it among two subjects.
They probably direct you to material science at the physics department because physics has so little to do with forensics.
Like most science subjects, material science can also be taught the engineering way or the science way.
Likes hawkeye295
If you have the time and the strength to learn more, then learning more is better than learning less. Even so, as Almeisan suggests, be careful about taking short-cuts. You may need more time for double-major
Likes hawkeye295
Hey, I am Andreas from Germany. I am currently 35 years old and I want to relearn math and physics. This is not one of these regular questions when it comes to this matter. So... I am very realistic about it. I know that there are severe contraints when it comes to selfstudy compared to a regular school and/or university (structure, peers, teachers, learning groups, tests, access to papers and so on) . I will never get a job in this field and I will never be taken serious by "real"...
Yesterday, 9/5/2025, when I was surfing, I found an article The Schwarzschild solution contains three problems, which can be easily solved - Journal of King Saud University - Science ABUNDANCE ESTIMATION IN AN ARID ENVIRONMENT https://jksus.org/the-schwarzschild-solution-contains-three-problems-which-can-be-easily-solved/ that has the derivation of a line element as a corrected version of the Schwarzschild solution to Einstein’s field equation. This article's date received is 2022-11-15...
