So, the question is: Is the concept of a function contravariant?
Troponin
My understanding of differential forms is that, given the map
\phi : V \to V^{*}
If f \in V^{*} is a 0-form (a real-valued function on V^{*}), then \phi defines the function \phi^{*} f on V
where \phi^{*}: F^{0}(V^{*}) \to F^{0}(V)
as the function such that \phi^{*}f(p)=f(\phi(p)).
So, since differential forms transform contravariantly, the 0-form (function) f transforms contravariantly (and therefore is contravariant...).
Because f doesn't have any indices, I decided to look online and see if that fact makes a difference in requiring the label "contravariant."
One of the first links was to a thread on physicsforums
https://www.physicsforums.com/showthread.php?t=311174
The debate is between "dx" and "MarkParis." It doesn't seem to reach an agreement in that thread, so I was wondering if anyone else could shed some light on it.
*IMO, the posts by "dx" are correct and meet my understanding of the topic. However, I'm still learning differential forms and there is certainly going to be nuances of the subject that I haven't understood yet...so I figured I'd see if anyone here has any input on this and/or the posts made in the linked thread.
The function f belongs to V*, so it can be expanded in a linear combination of a basis of V*. The coefficients of this expansion form a vector, that transforms contravariantly.
I think MarkParis's point is that strictly speaking it is df belongs to V*, not f itself.
Similarly it is d/dl that belong to V, not the curve itself.
And Hurkyl and dx's points are that df comes from f, just as d/dl comes from the curve, so in that sense f is "contravariant" while a curve is "covariant" (or is it the other way round, I never remember which is which).
The unifying notion of covariant and contravaraint comes from category theory.
There are lots of things we might be inclined to associate to any particular manifold -- things like its tangent bundle, the cotangent bundle, the set of curves defined on the manifold, its homology groups, et cetera.
Each of the things I mentioned above is a "functor", which here boils down to saying that if you have a differentiable function between manifolds, then you get a homomorphism between the kinds of things we are associating to the manifold.
The functor is covariant if the associated homomorphism goes in the same direction as the differentiable function, and contravariant otherwise. e.g. "Cotangent bundle" is contravariant, because for any differentiable function f:M-->N, the map f*:T*N-->T*M goes in the same direction.
Similarly "the set of curves" is covariant, because given f:M-->N, the associated function on the set of curves (i.e. "composition with f") turns a curve on M into a curve on N.
In this sense, "the sheaf of scalar fields" is contravariant, as is the "set of differentiable functions to R".
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
