Is a Home DSL Network Broadband?
  • Thread starter Thread starter LSE1234
    Home Network
The discussion revolves around the classification of home DSL networks as broadband, particularly in the context of Local Area Networks (LAN) and the nature of Ethernet communication. Participants explore the distinctions between broadband and baseband technologies, as well as the simultaneous communication capabilities within a LAN.
  • Some participants question whether home DSL networks can be classified as broadband in both DSL-internet and LAN contexts.
  • One participant suggests that "broadband" is simply a term for faster than dial-up connections.
  • There is a distinction made between broadband and baseband, with some participants focusing on local network communication rather than internet speed.
  • Another participant asserts that Ethernet operates as a baseband technology, utilizing a simple serial binary signal over differential pairs.
  • Wi-Fi is also described as baseband, using a single channel for each link but allowing multiple channels for simultaneous communication with different devices.
  • Participants discuss the capability of a LAN with multiple PCs to exchange data simultaneously, questioning how this relates to the classification of the network as baseband or broadband.
  • One participant emphasizes the importance of distinguishing between local network speeds and internet speeds in the discussion.
  • There is a suggestion that the term "broadband" may not apply to the inner communication of a network, which could still function under baseband principles.
Participants express differing views on whether home DSL networks should be classified as broadband, particularly in relation to local network communication. The discussion remains unresolved, with multiple competing perspectives on the definitions and implications of broadband versus baseband technologies.
Some participants' claims depend on specific definitions of broadband and baseband, and there are unresolved questions regarding the implications of network speed versus communication capabilities within a LAN.
LSE1234
Today's ethernet networks [LAN only I refer] we mention [1000baseT/100baseT - RJ-45] are broadband in nature or baseband? May mixed PCs send messages simultaneously to each other and internet, all to same network part, under one switch, for example...?
eg a HOME DSL NETWORK it it broadband both in DSL-INTERNET and LAN:PC-PC:WIFI or LAN ? OR NOT THE LATTER?
""Broadband"" is just faster than dial-up
I refer vs baseband, not in internet, but Local Area network(data not leave from network)? what is this of the two?
Since I've seen "Broadband" below 10k, I'd refer to the network instead the speed or frequencies.
Ethernet is baseband it's a simple serial binary signal on differential pair (single pair each way for 100Base, 2 pairs for gigabit).
wifi is base band in that it only uses a single channel for each link, but there are multiple channels for simultaneous comms with different devices.
In a LAN(100baseT) of 30 PCs , that you say is baseband may, 30 PCs work & exchange data same time, each other or from internet [LAN & Web]?
Yes, the routing is handled by the ethernet switch
Unless you are trying to confuse who ever it is your are talking to:
You refer to network speeds such as:
Provider\Provider (Name)\WAN SPEED
or
Local\Local Network\LAN SPEED
If you are about the network, leave off the work SPEED.
I refer on Local\Local Network\LAN SPEED
but not speed, but "communication same time" of course speed derives...
this achieved with only broadband ... the inner communication in network, or baseband is the same, ...?
30 of 30 PCs USE THE SAME CABLES TO SEND PACKETS SAME TIME/INSTANCE
10K
9K
