Is a Home DSL Network Broadband?
  • Thread starter Thread starter LSE1234
    Home Network
8 replies · 3K views · last reply
LSE1234
Today's ethernet networks [LAN only I refer] we mention [1000baseT/100baseT - RJ-45] are broadband in nature or baseband? May mixed PCs send messages simultaneously to each other and internet, all to same network part, under one switch, for example...?
eg a HOME DSL NETWORK it it broadband both in DSL-INTERNET and LAN:PC-PC:WIFI or LAN ? OR NOT THE LATTER?
I refer vs baseband, not in internet, but Local Area network(data not leave from network)? what is this of the two?
Since I've seen "Broadband" below 10k, I'd refer to the network instead the speed or frequencies.
Ethernet is baseband it's a simple serial binary signal on differential pair (single pair each way for 100Base, 2 pairs for gigabit).
wifi is base band in that it only uses a single channel for each link, but there are multiple channels for simultaneous comms with different devices.
In a LAN(100baseT) of 30 PCs , that you say is baseband may, 30 PCs work & exchange data same time, each other or from internet [LAN & Web]?
Unless you are trying to confuse who ever it is your are talking to:
You refer to network speeds such as:
Provider\Provider (Name)\WAN SPEED
or
Local\Local Network\LAN SPEED
If you are about the network, leave off the work SPEED.
I refer on Local\Local Network\LAN SPEED
but not speed, but "communication same time" of course speed derives...
this achieved with only broadband ... the inner communication in network, or baseband is the same, ...?
30 of 30 PCs USE THE SAME CABLES TO SEND PACKETS SAME TIME/INSTANCE
