Is a most general antiderivative required to be continous?
General_Sax
I've looked through my textbook and I've found no mention, but I've seen some posts on the Internet which explicitly state to check for continuity while taking the derivative certain functions.
Is it because: F'(x) = f(x)
I understand that a function is required to be continuous and differentiable, is that why we must check an antiderivative for continuity?
The derivative of 'certain functions' aren't continuous, that's true. But why do you think you need to check antiderivatives for continuity because of 'some posts'? You are being really vague here.
While taking the "derivative"? Well, certainly, if a function is not continuous at a given point, it does not have a derivative there. But are you talking about dertivatives or antiderivagives?
I don't understand what you are talking about. What do you mean by "F'(x)= f(x)"? And "a function is required to be continuous and differentiable" for what?
Do you mean "Because, if F(x) is the anti-derivative of f(x) then F'(x)= f(x) and a function is differentiable at a given point only if it is continuous there, must the anti-derivative of a function be continuous at that point?" The answer to that is "yes". Although you can have situations where F(x) is the anti-derivative of f(x) except at a single point- and then F may not be continuous at that point.
Yes, that's exactly what I meant. Sorry for being so unclear.
Basically, I had to find the most general anti-derivative of an absolute value function, so I was searching on the Internet and found a similar question.
They advised taking the anti-derivative on the individual intervals and then checking F(x) for continuity be equating the applicable limits. This allows for one to solve for the constants (in a sense).
However, I could never find a reason for why this is so.
"Although you can have situations where F(x) is the anti-derivative of f(x) except at a single point- and then F may not be continuous at that point."
If you had an definite integral and the anti-derivative was discontinuous would you sum the areas before and after the discontinuity?
without getting too rigourous... if you think of the anti-derivative as "the area under the curve", then if F(x) = \int_a^x dx f(x) and f is continuous, it should be reasonably obvious that F will also be continuous (and differentiable, with F'(x) = f(x))
if you allow some less well behaved functions (like the dirac delta function \delta(x)) then the inetgral doesn't have to be conitinuous (\int_{-\infty}^x dx \delta(x) is the step function, though \delta(x)) is not acontinuous function
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
