Is it Better to Use a Diagram or Math to Calculate Displacement?
  • Thread starter Thread starter Balsam
    Displacement
The discussion revolves around calculating displacement in physics, specifically comparing the use of mathematical calculations versus diagrams to determine the displacement between two points with given directions (east and west).
  • Mixed
  • Participants explore the mathematical approach of using delta d = df - di, questioning how to assign positive and negative values to positions based on direction. They also discuss the potential complications when points do not lie on the same line and consider whether drawing a diagram might clarify the situation.
The conversation is ongoing, with participants sharing insights about the mathematical method and the potential benefits of visual representation. Some suggest that diagrams could enhance understanding, particularly in more complex scenarios involving multiple directions.
Participants note that the original problem involves positions defined in terms of cardinal directions, which may influence how displacement is calculated. There is also mention of the challenges that arise when points are not aligned along a single axis.
Balsam
Member advised to use the homework template for posts in the homework sections of PF.
If you're calculating displacement using delta d=df-di, do you make one position positive and one negative and then add?
For example, if your first position was 23m[W] and the final position was 34 m [E], would you just do, 34- (-23), making the position that is west negative and the east position positive?
You can do this for this example. With how you described it, it like taking the x-axis. There, you would be setting the 0 point at the origin, such that any distance westward (in your case, the 23m) is negative and anything eastward positive, which is legitimate. The only time this may get a bit trickier thinking of it this way is if you aren't given two points along the x-axis. Say, for example you were given the first point 23m West and the second point 34m East and 10m North. In this case, you would not just add 23m+34m+10m to get 67m because the 2 points do not lie on the same line. However, in your case, this works.
Would it make more sense just to draw a diagram and see the distance and direction of the final point from the starting point?
In general, I believe pictures always make this more intuitive and easy to understand. If you drew a picture of the case you presented in the original post, it would be evident that the two points lie on the same horizontal line. In this case, your method works.
However, in the case I gave as an example, if you plotted these two points and connected them with a straight line, it is obvious that the line connecting the two points has a non-zero slope. In this case, one can simply just use the Pythagorean Theorem to solve for the hypotenuse of the right triangle to get the displacement.
  • · Replies 0 ·
  • · Replies 56 ·
