Is mass conserved in terms of Special Realitivity
  • Thread starter Thread starter DODGEVIPER13
    Mass Terms
Mass is not a conserved quantity under Special Relativity; instead, mass-energy is conserved. The equation E=mc^2 illustrates the equivalence of mass and energy, indicating that mass can be transformed into energy and vice versa. Discussions clarify that while rest mass is invariant, relativistic mass changes with speed, which can lead to misconceptions. The consensus is that total energy remains constant in an isolated system, but mass itself can change, particularly in high-energy scenarios like nuclear reactions. Ultimately, the focus should be on energy conservation rather than mass conservation in relativistic contexts.
DODGEVIPER13
Is mass a conserved quantity under Special Realitivity?
E=mc^2
Total energy is always conserved in an isolated closed system, and since mass is just another form of energy, then mass would be conserved in a realtavistic situation right?
I'm not sure what SR and mass have to do with each other but certainly if you use E=mc^2 you are specifically saying that mass does NOT have to be conserved because you can turn it into energy.
But being that energy is neither created nor destoryed would transformation of the Mass efect the amounnt of mass you have because I would think it would remain constant?
Huh ?
Energy is created and mass is destroyed. How do you think an atom bomb works?
EDIT: perhaps a more pertinent question rather than one about the bomb would be, what do you think E=mc^2 MEANS ?
Total Energy = (Rest Mass)(Speed of light in a vacumm)^2. and I believe it states the equivalence between energy and mass.
Right. Which means mass is NOT conserved. Doesn't that answer your question?
yes thanks
"mass-energy", of course, is conserved.
thanks Halls so it is conserved
And what do you mean by "it". Your original question was "is mass conserved". The answer to that is NO, so if the above refers to mass, then NO, it is not conserved.
You seem to have some need to hear that mass is conserved. It isn't. As Ivy said, mass-energy IS conserved.
You should also realize that when physicists refer to mass, they're talking about the rest or invariant mass of an object.
Journalists and other laypersons have an affinity for the idea of relativistic mass because it sounds cool to say the mass of an object changes with its speed. Relativistic mass, however, is really just the relativistic energy of the object divided by the constant c2, so you might as well just talk about the object's energy instead of its (relativistic) mass. It just doesn't sound as cool to say that an object's energy increases as it speeds up.
