Is mechanical engineering the right thing to learn?
Mechanical engineering provides a strong foundation for designing car parts, covering essential theories and principles applicable across various engineering fields. While automotive engineering focuses specifically on vehicles, it may limit career prospects compared to a broader mechanical engineering degree. Resources for learning mechanical engineering include online courses, books, and tutorials, though some platforms may lack complete materials. Pursuing an IMechE Accredited MEng (Hons) Mechanical Engineering course is recommended for better job opportunities in automotive design. Gaining practical experience through internships is also advised for aspiring engineers.
Tapeman
Hello, this is my first post on physics forum. I really want to learn to design car parts, from engine blocks to wish bones. From what I've found it seems like mechanical engineering would definitely be useful for a foundation, but I just want to make sure there isn't a field more specific I could be studying.
Also what are some good sources for learning mechanical engineering? I looked at MIT Open Courseware but every course seemed to be missing lectures. I'm fine with any medium, books, videos, tutorials, etc.
With mechanical engineering, you will understand a whole lot of theories and principles, that you may as well apply to design of cars and their parts. With automobile engineering, you will probably learn these same principles, but apply them only to cars, engines etc. during your entire period of graduation. So you will be better at cars as an automobile engineer , than a mechanical engineer. The only drawback is however, you will be good, only at automobiles. That might limit career prospects for you.
Having never finished high-school, I can give you only my opinion. That is, you can't go wrong with Mechanical. I base that upon the fact that Auto, Aero, Structural, etc. all have a base in Mechanical. Again, though, that is only my opinion an outsider; real engineers might feel otherwise.
Steer away from any course called automotive engineering - never considered to be on par with other engineering disciplines. Do an IMechE Accredited MEng (Hons) Mechanical Engineering course - you'll have the best chance of getting a graduate job designing car parts :) - the honest truth - oh, and do a summer internship in an engineering company.
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
