Is My Bipolar Base Emitter Voltage Calculation Accurate?
  • Thread starter Thread starter falcon555
    Base Npn Voltage
The discussion revolves around evaluating the accuracy of a bipolar base emitter voltage calculation. A participant suggests performing a backward calculation by inserting the results for Vbe into the original equations to verify the results. Another participant admits they haven't checked the entire calculation due to its complexity but supports the idea of using backward calculations as a method for confirmation. The conversation emphasizes the importance of validating calculations in electronics. Overall, the thread highlights the need for thorough verification in technical calculations.
falcon555
Hi again dear friends. , hope all are doing well.
Please could some one evaluate my work and advise me in case any correction is required.
Have a good day
Hi Falcon, did you already try a calculation backwards?
That means: To insert the results for Vbe into the orignal equations?
No
If you advise me to do that , then I will do it.
What about the formulae and method I have chosen, are they correct?
falcon555 said:
No
I must admit that I did not check the whole calculation (extensive and hard to read).
Therefore my recommendation. I think, such a calculation backwards is a simple method for confirming the result.
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
