Is My Epsilon-Delta Proof Correct?
  • Thread starter Thread starter BrianMath
    Proof
BrianMath
Using the Epsilon-Delta Definition of a limit, show that
\lim_{z\to z_0} \overline{z} = \overline{z_0}
where \overline{z} is the conjugate of z.
|\overline{z}|=|z|
\overline{z_1}-\overline{z_2} = \overline{z_1-z_2}
\forall \varepsilon > 0, \exists \delta > 0: 0 < |z-z_0| < \delta \implies |\overline{z} - \overline{z_0}| < \varepsilon
|\overline{z}-\overline{z_0}| = |\overline{z-z_0}| = |z-z_0|
Choose \delta = \varepsilon
|\overline{z-z_0}| = |z-z_0| < \delta = \varepsilon
I'm currently teaching myself Complex Variables using Churchill and Brown's text, but do not have access to any instructors to comment on my work (summer before university). This is the first time that I'm seeing \varepsilon-\delta proofs, so I want to make sure that my proof is correct.
You've got the main part sort of backwards. What you've shown is what I call the scratch work that you do on the side before writing up the formal proof. It's how you decide what relationship δ should have to ε so that when z is within the 'δ - neighborhood' of z0, then your function of z, in this case \bar{z}, is within the 'ε - neighborhood' of the limit L, in this case \bar{z}_0.
Yes, you start with ε > 0 as you did. Then you set δ, in this case you said δ = ε.
Next show that for any z such that 0 < | z - z0 | < δ, then it follows (by algebra, etc.) that \left|\bar{z}-\bar{z}_0\right|&lt;\epsilon\,.
Okay, thank you. I was wondering if I had the right order of everything.
So is this right, now?
Let \varepsilon &gt; 0 and choose \delta = \varepsilon. Then
0 &lt; |z-z_0| &lt; \delta \implies |\overline{z}-\overline{z_0}| = |\overline{z-z_0}| = |z-z_0| &lt; \delta = \varepsilon
|z-z_0|&lt;\delta \implies |\overline{z}-\overline{z_0}| = |\overline{z-z_0}| = |z-z_0| &lt; \delta = \varepsilon
That's much better.
Probably should say 0&lt;|z-z_0|&lt;\delta \implies |\overline{z}-\overline{z_0}\,| = \dots
You don't want (or need) z = z0.
SammyS said:
That's much better.
Oops, oh yeah, I did forget the greater than 0 part. :biggrin:
Thank you very much for your help.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
