Partition Axioms for Set P: Is P a Partition of Set A?
  • Thread starter Thread starter iHeartof12
    Partition Set
iHeartof12
For the given set A, determine whether P is a partition of A.
A= ℝ, P=(-∞,-1)\cup[-1,1]\cup(1,∞)
Is it correct to say that P is not partition? I don't understand why.
Thank you
A partition, as far as I know, is just a division of the set into non-intersecting subsets s.t. the union of all subsets is the original set and all subsets are non-empty.
How can you show whether or not the sets are non-intersecting? How can you show whether or not the union of the sets covers the original set? It is pretty easy to show no subset is empty.
More simply, do any of the subsets overlap with other subsets? Is there any element of ℝ that isn't in one of the subsets? If either of these is true, then the definition of a partition fails. If both are false, then we have satisfied the definition of a partition.
Here's the definition of partition as described by my one of my professor's notes:
Let X \not= \emptyset and let each A_\alpha, where \alpha \in \Omega, be a subset of X. Then the family of subsets \{ A_\alpha : \alpha \in \Omega \} of X is a partition of X if and only if
(i) A_\alpha \not= \emptyset, \forall \alpha \in \Omega
(ii) \bigcup_{\alpha \in \Omega} A_\alpha = X
(iii) \forall \alpha, \beta \in \Omega, either A_\alpha = A_\beta or A_\alpha \cap A_\beta = \emptyset.​
Does this make sense?
The definition makes sense, yes. Which of these three axioms would you say are true in the problem you're considering?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
