- #211
NateTG
- 2,452
- 7
It's actually a relatively straightforward idea so someone has surely done this, but I don't have sufficient QM literacy to provide you with a paper. The "Proof that all signal local theories have local interpretations" thread is an attempt to make a legible general version of this, but the following should give you an idea of what I mean:DrChinese said:2. I wonder if you might have anything up your sleeve in the way of an example or reference I could take a peek at? Or perhaps you can elaborate on your position? You had mentioned this in an earlier post too in which you were talking about the undefined results.
Let's assume (for the sake of discussion) that there is a local hidden state theory for QM, and that we have a repeatable EPR set-up where we the polarization of two entangled photons along one of three axes each with binary measurements, and that we can only make one meaningful measurement on each photon. And, let's also assume that this particular set up is signal local.
Then we can restrict the state space to a list of all the possible combinations of measurement results - so the state space has size [itex]2^6=64[/itex].
Now, there are a large number of subsets of the state space, [itex]2^{64}[/itex] of them in fact, but we can only experimentally test the probability for [itex]48[/itex] subsets.
If we simply assign the appropriate (and experimentally verifiable) probabilities to those [itex]48[/itex] subsets, and, in addition assign the probability [itex]0[/itex] to the empty set, and the probability [itex]1[/itex] to the entire set it turns out that signal locality insures that we end up with a probability measure on the state space. (This last clause is really what that other thread is about.)
Now, this interpretation clearly assumes that there is a local hidden state, and is local, but does not run into the Bell's theorem type contradictions.
